#2771: osgeo7 snapshot failing and secure can't restart
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
the first issue was after I shut down secure, it wouldn't start.
Gave error something to effect:
Failed to run: zfs set mountpoint
To fix I did:
sudo zfs set mountpoint=/var/snap/lxd/common/lxd/storage-
pools/default/containers/secure canmount=noauto osgeo7/containers/secure
zfs umount osgeo7/containers/secure
zfs mount osgeo7/containers/secure
live was having similar issue so I did the same and stated it up.
secure had an additional issue was one I couldn't find anywhere:
This was a complicated one, I documented my change here -
https://discuss.linuxcontainers.org/t/lxc-snapshot-and-lxc-start-error-
instance-snapshot-record-count-doesnt-match-instance-snapshot-volume-
record-count/14245/3
More detail here:
first I made a backup of the lxd database to inspect, with this:
sudo cp /var/snap/lxd/common/lxd/database/global/db.bin lxd-global-220601
Then I inspected the sql lite backup as follows:
sudo apt install sqlite3
sqlite3 lxd-global-220601
# in sqlite console
.tables
.mode column
.headers on
SELECT count(*) FROM instances AS v INNER JOIN instances_snapshots AS vs
ON v.id = vs.instance_id WHERE v.name = 'secure';
output: 32
SELECT count(*) FROM storage_volumes AS v INNER JOIN
storage_volumes_snapshots AS vs ON v.id = vs.storage_volume_id WHERE
v.name = 'secure';
output: 37
SELECT v.id
FROM
(SELECT vs.* FROM storage_volumes AS v INNER JOIN
v.name = 'secure') AS v
LEFT JOIN
(SELECT vs.* FROM instances AS v INNER JOIN instances_snapshots AS vs ON
v.id = vs.instance_id WHERE v.name = 'secure') AS i ON i.name = v.name
WHERE i.name IS NULL;
Which resulted in these numbers for storage_volumes_snapshots
4701
4714
4737
4761
4779
Then ran this:
lxd sql global "DELETE FROM storage_volumes_snapshots WHERE id
IN(4701,4714,4737,4761,4779)"
Then I was able to do
lxc snapshot secure
lxc start secure
I'll close this ticket out once I've fixed the other affected containers.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2771#comment:2>
OSGeo <https://osgeo.org/>
