#2782: Can't add new user to shell group
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: critical | Milestone: Unplanned
Component: Systems Admin | Keywords:
I was trying to add a new user to shell group and I'm getting a strange
error.
Not sure if it has to do with the python3 upgrade or something I am
missing.
https://id.osgeo.org/ldap/shell
The new user geoserverdocs per #2640. It ends up getting listed, but
can't ssh with it so assume it's missing some bits
Traceback (most recent call last): File "/usr/lib/cgi-
bin/auth/ldap_shell.py", line 293, in shell_enable_userid( new_uid ) File
"/usr/lib/cgi-bin/auth/ldap_shell.py", line 153, in shell_enable_userid
uidNumber = get_and_increment_uidNumber( l ) File "/usr/lib/cgi-
bin/auth/ldap_shell.py", line 135, in get_and_increment_uidNumber
l.modify_s( target, ml ) File "/usr/lib/python3/dist-
packages/ldap/ldapobject.py", line 631, in modify_s return
self.modify_ext_s(dn,modlist,None,None) File "/usr/lib/python3/dist-
packages/ldap/ldapobject.py", line 603, in modify_ext_s msgid =
self.modify_ext(dn,modlist,serverctrls,clientctrls) File "/usr/lib/python3
/dist-packages/ldap/ldapobject.py", line 600, in modify_ext return
self._ldap_call(self._l.modify_ext,dn,modlist,RequestControlTuples(serverctrls),RequestControlTuples(clientctrls))
File "/usr/lib/python3/dist-packages/ldap/ldapobject.py", line 315, in
_ldap_call result = func(*args,**kwargs) TypeError: ('Tuple_to_LDAPMod():
expected a byte string in the list', 'N')
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2782>
OSGeo <https://osgeo.org/>
Priority: critical | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Resolution:
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2022-II
Comment:
On further inspection, this appears to be the same error as detailed here
https://github.com/python-ldap/python-ldap/issues/329
I'll take a stab and fixing and hopefully figure out how to push changes
via ansible (all those changes I haven't pushed yet)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2782#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Managed to fix this and test on osgeo4 staging before deploying to
production.
Fix on https://git.osgeo.org/gitea/sac/web-cgi-
bin/commit/93e3e5f6e02f88c34af79812776387e014cc695b
I thought it wasn't working original, but I needed to restart the nlcd and
related services on the container I was testing with, because the
production ldap was still cached in service memory.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2782#comment:2>
Keywords: ldap |
Changes (by strk):
* keywords: => ldap
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2782#comment:3>
