#2788: old-web won't start Instance snapshot record count doesn't match instance
snapshot volume record count
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Keywords:
old-web is having the issue from past of bad snapshots and the newer lxd
versions prevent containers from starting if they have them.
This issue I reported upstream and details were here -
https://discuss.linuxcontainers.org/t/lxc-snapshot-and-lxc-start-error-
instance-snapshot-record-count-doesnt-match-instance-snapshot-volume-
record-count
The fix they implemented was to automatically fix these issues where there
is no data loss (of backup snapshots). So for this one we have to do
manually.
Affected sites are old.www.osgeo.org, fdo.osgeo.org, mapguide.osgeo.org.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2788>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
I had deleted the links in nginx container /etc/nginx/sites-enabled/ (for
these 3) so nginx wouldn't complain.
steps to fix, from osgeo7 host
lxd sql global "SELECT v.id, v.name FROM (SELECT vs.* FROM storage_volumes
AS v INNER JOIN storage_volumes_snapshots AS vs ON v.id =
vs.storage_volume_id WHERE v.name = 'old-web') AS v LEFT JOIN
(SELECT vs.* FROM instances AS v INNER JOIN instances_snapshots AS vs ON
v.id = vs.instance_id WHERE v.name = 'old-web') AS i ON i.name = v.name
WHERE i.name IS NULL;"
Returned:
| id | name |
| 4719 | snap1 |
Then delete the orphan volume:
lxd sql global "DELETE FROM storage_volumes_snapshots WHERE id IN(4719)"
Then doing the below works
lxc snapshot old-web
lxc start old-web
Once this is started:
lxc exec nginx bash
ln -s /etc/nginx/sites-available/mapguide.osgeo.org /etc/nginx/sites-
enabled/mapguide.osgeo.org
systemctl reload nginx
I'm not going to bother with fdo.osgeo.org or old.www.osgeo.org unless
someone complains. Those two should not be used anymore. At a glance
last update for fdo.osgeo.org was in 2015 and osgeo.org and www.osgeo.org
have been moved for a while.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2788#comment:1>
