#2822: Upgrade tracsvn to bullseye
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Keywords:
Tracsvn is currently at debian buster which is now oldoldstable.
Need to upgrade this to at least bullseye. Bookworm the next stable is in
RC phase.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2822>
OSGeo <https://osgeo.org/>
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
Doing this should also give us Gitea support for the Agit workflow,
allowing us to create pull requests directly via `git push`:
https://github.com/go-gitea/gitea/issues/27579#issuecomment-1765074621
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2822#comment:2>
Keywords: gitea, trac, svn |
Changes (by strk):
* keywords: => gitea, trac, svn
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2822#comment:3>
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin | Resolution:
Comment (by strk):
Bookworm is current stable, for the record, so we should probably go there
(Debian 12)
Ticket URL: <#2822 (Upgrade tracsvn to bullseye) – OSGeo;
OSGeo <Gter - OSGeo;
Comment (by robe):
Replying to [comment:5 strk]:
there (Debian 12)
As I recall you can't skip versions, so you need to go to bullseye first
and if we have to go there anyway we might as well confirm things still
work before venturing to bookworm.
