#2824: Upgrade wordpress (osgeo.org) to bullseye
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Keywords:
osgeo7-wordpress instance is currently at buster and PHP 7.3
Given PHP 7.3 is at EOL and has some security vulnerabilities, this will
be my priority to upgrade.
I will upgrade osgeo4-wordpress-dev first which is a snapshot
osgeo7-wordress with https://dev.www.osgeo.org being about a month or 2
old of current production www.osgeo.org to confirm no issues.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I've upgraded wordpress-dev to bullseye (debian 11).
Kept the /etc/ldap/ldap.conf and /etc/ssh/sshd_config files, though the
sshd_config I was surprised to not see anything really custom, all just
commented out stuff and include/sshd_conf.d so I suspect that one i should
have allowed overwrite with package maintainers.
The final apt dist-upgrade caused some issues with
Created symlink /etc/systemd/system/sysinit.target.wants/systemd-
pstore.service → /lib/systemd/system/systemd-pstore.service.
Failed to get load state of systemd-networkd.socket: No buffer space
available
and abruptly shutdown, and had to manually start it back up and showed
incomplete install.
Also on continue, after running
dpkg --configure -a
seems to be stuck on:
Failed to reload daemon: Transport endpoint is not connected
forcing a continue results in more errors:
dpkg: dependency problems prevent configuration of systemd-timesyncd:
systemd-timesyncd depends on systemd (= 247.3-7+deb11u1); however:
Package systemd is not configured yet.
dpkg: error processing package systemd-timesyncd (--configure):
dependency problems - leaving unconfigured
At anyrate even after resolving these issues, don't plan to upgrade
production until after board vote is over to minimize on disruption.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824#comment:1>
Priority: normal | Milestone: Sysadmin Contract 2023-I
Keywords: |
Comment (by robe):
In the middle of this so site is down at moment.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824#comment:3>
Keywords: |
Comment (by robe):
Ran into serious problems so rolled back. I think I'll just rebuild this
from scratch on osgeo9 using the latest bullseye image I created. Maybe
this time I'll go with nginx since wordpress/nginx performance is supposed
to be better than apache/wordpress.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824#comment:4>
Keywords: |
Comment (by robe):
I have a new container on osgeo9 called wordpress, and have the site
working on there but haven't migrated yet. I want to resetup dev to use
this container, kick the tires a bit before I make the osgeo9 production
one live.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824#comment:5>
#2824: Build new wordpress container, move to osgeo9
Keywords: |
Changes (by robe):
* summary: Upgrade wordpress (osgeo.org) to bullseye => Build new
Comment:
I'm going to start the process shortly of moving wordpress (osgeo.org)
from osgeo7 to osgeo9.
I've already built a new container on osgeo9 to house it which switches
from using apache to using nginx, PHP 7.4 and is running a clean new
install of bullseye.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824#comment:6>
Keywords: |
Comment (by robe):
Okay I have it now live on osgeo9 now, and put an undermaintenance sign on
the osgeo7 one.
I'll keep that up for a few days before I stop the container for good.
Anyone seeing the under maintenance sign, has a stale dns entry.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824#comment:7>
Keywords: |
Comment (by cvvergara):
Q. so staging will be in osgeo9 right?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824#comment:8>
Keywords: |
Comment (by robe):
Replying to [comment:8 cvvergara]:
No osgeo9 is production and is called wordpress
osgeo4 (at moment has both a staging and a dev). Staging I'll probably
get rid of and reset it up on the dev.
So osgeo4 wordpress-dev, wordpress-staging. Both are copies of what I had
on osgeo9 from a week or so ago when you tested them.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824#comment:9>
Keywords: |
Comment (by robe):
P.S I still need to move over the cronjobs from osgeo7, but you can start
setting up what you are were talking about on the postgresql-15 I
installed (which is in all of the envs).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824#comment:10>
Keywords: |
Comment (by robe):
okay I moved over the cronjobs. While copying over people's homedrives, I
found some unexpected ones filled with stuff. I copied them over, but
wonder, if these should even be on this server.
cvvergara -- this one is expected
wildintellect - bunch of byobu, what is this for?
rouault - swig-2.0.12 (what is it for and should it even be on the
wordpress server)
It's possible wildintellect and rouault were copied over from a much
earlier time (when osgeo.org was housed on osgeo6).
I didn't check the dates.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824#comment:11>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
this was done a while ago. wordpress is now on osgeo9 using nginx instead
of apache now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2824#comment:12>
