#2827: Upgrade osgeo3 lxd host to Ubuntu 22.04
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Keywords:
osgeo3 is currently running 20.04. Plan to upgrade it to 22.04.
Note osgeo4, it's closest compadre has already been upgraded to 22.04 with
no issues.
Should wait off till elections are over.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2827>
OSGeo <https://osgeo.org/>
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Going to start this process shortly.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2827#comment:2>
Keywords: |
Comment (by robe):
I'm going to hold off on this until I have console access.
I seem to have lost console access to the osgeo3 server, and like to have
that before I do a hard upgrade in case something goes wrong and needs a
hard reboot or some other more invasive fix.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2827#comment:3>
Keywords: |
Comment (by robe):
Now that I have console access again, I'm going to start the process of
upgrading.
This will affect matrix, repo.osgeo.org, gallery, monitor, geo-docs
I don't expect more than 30 minutes downtime.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2827#comment:4>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Took a little longer than I had hoped.
nexus after the upgrade of host, the docker would not start with error.
cgroups: cannot found cgroup mount destination
Doing the same fix as I did on osgeo4 (to allow creating old containers
did the trick)
https://discuss.linuxcontainers.org/t/2nd-system-upgraded-from-
ubuntu-20-04-w-working-lxd-to-ubuntu-22-04-lxd-again-not-working/14009/30
Edit /etc/default/grub and ensure that GRUB_CMDLINE_LINUX contains
systemd.unified_cgroup_hierarchy=false:
E.g.
GRUB_CMDLINE_LINUX="systemd.unified_cgroup_hierarchy=false"
Then run:
sudo update-grub
sudo reboot
In the process I also ended up upgrading nexus and docker. I'll write up
in separate ticket.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2827#comment:5>
