#2837: problem to merge Pull requests from
https://git.osgeo.org/gitea/foss4g/video.foss4g.org/
Reporter: astrid_emde | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
It is not possible to merge the PR 17 from
There is a PR 17 that we would like to merge. I can see it when I am not
logged in. But when I login I get a 500 Error when I click on the link.
https://git.osgeo.org/gitea/foss4g/video.foss4g.org/pulls/17
@jefmcenna should merge the PR 17
- PR 16 is obsolete and can be delited
http://video.foss4g.org/
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2837>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I confirm I get a 500 too when I'm logged in, but can see it when I'm not
logged in. Very strange.
I'll check the logs in a bit.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2837#comment:1>
Priority: normal | Milestone: Sysadmin Contract 2022-II
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2022-II
Comment:
As best I can tell from the logs, the issue is this one
https://github.com/go-gitea/gitea/issues/20621
Which looks like it might be fixed in the latest micro of 1.17.
I'll try to upgrade and see if it fixes it.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2837#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
okay upgrading didn't fix the issue.
The issue ultimately was because the last upgrade probably didn't tick
the **Enable Respository Pull Requests** in your fork, which might be a
new setting I guess
To fix
https://git.osgeo.org/gitea/astrid_emde/video.foss4g.org/settings
I went ahead and updated that on your repo and now I can see the pull
requests when logged in.
[[Image(enable_pull_requests.png)]]
So if any one else runs into the issue. That's the fix to do that on your
fork.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2837#comment:3>
Keywords: |
Changes (by robe):
* Attachment "enable_pull_requests.png" added.
Keywords: |
Comment (by astrid_emde):
@robe - thank you for your support. Looks like all is fine now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2837#comment:4>
