#2842: new project in git
Reporter: lucadelu | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
I would like to creare a new project in Git under FOSS4G umbrella. I would
like to create https://git.osgeo.org/gitea/org/foss4g/resources but I'm
not able.
If I try to create a new project it will be created under my user.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2842>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Changes (by strk):
* cc: Jeff McKenna (added)
Comment:
I guess you must be owner in order to create a repository there.
Better ask Jeff McKenna
https://git.osgeo.org/gitea/org/foss4g/teams/owners
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2842#comment:1>
Keywords: |
Comment (by strk):
I seem to be able to create repositories under the "foss4g" organization,
via this link:
https://git.osgeo.org/gitea/repo/create?org=67
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2842#comment:2>
Keywords: |
Comment (by lucadelu):
Replying to [comment:2 strk]:
organization, via this link:
For me it return "Forbidden"
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2842#comment:3>
Keywords: |
Comment (by Jeff McKenna):
Bizarre, for me also it only displays a blank page with the words
"Forbidden"
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2842#comment:4>
Keywords: |
Comment (by robe):
Okay that's odd, but Jeff didn't you create the other repositories?
I did a test giving my test robe2 account owner rights to foss4g org.
I confirm like Jeff that I too get a forbidden. My sysadmin robe, like
strk I have no issue creating a repository. I'm investigating what could
be the issue here.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2842#comment:5>
Keywords: |
Comment (by robe):
@Jeff Mckenna
That was weird. Jeff can you try again.
I was able to have my robe2 test account be able to not get Forbidden by
doing, one of two things. Not sure which one did it
1) On settings checking the box "Repository admin can add and remove
access for teams", that wasn't checked for some reason, but assume it
should be
2) Editing Owners group and just resaving without changing anything
I forget to check before doing each step if I could add. Anyrate I think
it might have been an upgrade issue and resaving the settings forced a
population of new bits that weren't set.
I removed my robe2 account from owners role and now get a Forbidden as
expected.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2842#comment:6>
Keywords: |
Thanks @robe I'm now (again) able to create repositories.
@lucadelu I'm created the 'resources' repo and given you privileges.
https://git.osgeo.org/gitea/foss4g/resources
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2842#comment:7>
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
* milestone: Unplanned => Sysadmin Contract 2022-II
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2842#comment:8>
