#2851: patch update on matrix
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2022-II
Component: Systems Admin | Keywords:
Been a while since patch updates
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2851>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
I kept the current /etc/matrix-synapse/log.yaml.
changes in case we want to apply them
--- /etc/matrix-synapse/log.yaml 2022-09-21 15:17:55.934755168
+0000
+++ /etc/matrix-synapse/log.yaml.dpkg-new 2022-11-22
11:14:55.000000000 +0000
@@ -6,7 +6,7 @@
# Synapse also supports structured logging for machine readable logs
which can
# be ingested by ELK stacks. See [2] for details.
-# [1]: https://docs.python.org/3.7/library/logging.config.html
#configuration-dictionary-schema
+# [1]: https://docs.python.org/3/library/logging.config.html
# [2]: https://matrix-
org.github.io/synapse/latest/structured_logging.html
version: 1
@@ -62,13 +62,6 @@
# information such as access tokens.
level: INFO
- twisted:
- # We send the twisted logging directly to the file handler,
- # to work around https://github.com/matrix-
org/synapse/issues/3471
- # when using "buffer" logger. Use "console" to log to stderr
instead.
- handlers: [file]
- propagate: false
root:
level: INFO
Configuration file '/etc/matrix-synapse/log.yaml'
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2851#comment:1>
Keywords: |
Comment (by robe):
Rebooting seems to have made it not able to get a new ip.
I suspect something amiss with ufw firewall conflicting with lxd which I
have seen before, though usually not until I upgraded to ubuntu 22.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2851#comment:2>
Keywords: |
Comment (by robe):
Adding these rules to osgeo3 host seems to have fixed
https://discuss.linuxcontainers.org/t/lxd-bridge-doesnt-work-with-ipv4
-and-ufw-with-nftables/10034/17
sudo ufw allow in on lxdbr0
sudo ufw route allow in on lxdbr0
I'll update ansible scripts to include those
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2851#comment:3>
