#2868: Upgrade wiki.osgeo.org to MediaWiki 1.39.1
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Keywords:
I'll do this first on staging before production.
After that I will address #2863
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2868>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
As discussed on #2896 I seem to only be able to upgrade to 1.38 (done in
staging) before the LDAP stops working. Need to troubleshoot the LDAP
issue with 1.39. before I can proceed with this.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2868#comment:1>
Priority: normal | Milestone: Sysadmin Contract 2024-I
Component: SysAdmin | Resolution:
Keywords: |
Comment (by strk):
Current version is in Version - OSGeo ( 1.35.9
It would be nice to do this via Ansible, which now DOES have a "wiki" role
Ticket URL: <Making sure you're not a bot!;
OSGeo <Gter - OSGeo;
Keywords: |
Comment (by robe):
FWIW I did figure out the issue with LDAP so grass-wiki is running a newer
version 1.41.0
Type: task | Status: closed
Component: SysAdmin | Resolution: wontfix
Keywords: |
Changes (by strk):
* resolution: => wontfix
* status: new => closed
Comment:
Ok so I filed a new ticket to go to current stable (1.44): #3433
Closing this as a "won't fix"
