#2877: tracsvn down out of disk space
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Keywords:
Trac shutdown because of out of disk isues agin.
I cleared some snapshots and added another 100GB.
Checking to see if its just a snapshot or something else eating the disk
space
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2877>
OSGeo <Gter - OSGeo;
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Okay confirmed most of the size taken up by /home/git/gitea-data/repo-
archive.
Clicking the https://git.osgeo.org/gitea/admin
"Delete all repositories' archives (ZIP, TAR.GZ, etc..)"
cleared 200GB of space.
so down to only 97GB used.
strk thinks it might be a bots crawling, as gitea creates a physical file
whenever an archive is requested.
Also seems we might not have gitea cron job enabled. Going to enable that
and close this out and see how it goes.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2877#comment:1>
OSGeo <https://osgeo.org/>
Keywords: |
Comment (by robe):
gitea is running crons, but not for
"Delete all repositories archives(Zip, tar, gz, etc)"
it's running another "Delete all repository archives"
I think we need to change the app.ini to enable this one as it's turned
off by default.
But maybe we should just see how much this builds up. This job has never
been run so if it took many years to get up to 200GB, maybe it doesn't
need to run that often.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2877#comment:2>
Keywords: |
Comment (by strk):
It's running the "delete old archives" where old can be defined in app.ini
(by default 24h which is what we use). Schedule can also be defined, by
default is at midnight, which we're using. Keep an eye on that directory
and please verify that the oldest one was created not more than 24h before
"now".
Possible improvement: schedule more frequently than every midnight (once
each hour?), make "old" happen sooner (every 8 hours?).
The "delete all archives" is only needed if we think someone could create
a lot more archives in a short period of time. This IS technically
possible and I don't see any way to prevent this unless by using some
limiting factor at the nginx level. Would be worth an issue upstream for
Gitea to allow NEVER saving those files, or providing other tasks to
determine when to clean based on SIZE of archive directory rather than AGE
of those archives
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2877#comment:3>
Keywords: |
Comment (by robe):
Looks like it hasn't run yet as I still see N/A for previous time.
I'll check in the next 24 hrs to see if things have changed. I assume it
goes by tracsvn clock time which is set for PST and currently Fri 13 Jan
2023 04:44:06 PM PST
right now the repo-archive folder has grown to 53G.
I did up the container size an additional 100G just in case doing snapshot
makes it run out of disk space.
Total space used at moment is 144G.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2877#comment:4>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Seems to be working repo-archive folder is now at 16G and space used in
container is 107G. So a 30G reduction from last I checked.
The monitoring page shows it last ran at - Sat, 14 Jan 2023 00:00:00 -0800
(and has run for 2 times).
I've changed the tracsvn container snapshots to run at -- 08:32 UTC
Before they were running at - 18:01 UTC
So that way the snapshots can be as small as they can be.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2877#comment:5>
Keywords: |
Comment (by robe):
Thinking about this more, maybe it would be better to run every 12 hrs,
I'll leave it alone for now. The reason I'm thinking that is right now
the last osgeo4 backup snapshot runs at 5:13 UTC so it would be heftiest
at that time.
I suppose I could just change that backup schedule (though that one
applies for all osgeo7 containers). Not a huge deal though since it is
much smaller now, and 40G here an there is not a huge deal only case is
when a bot comes along and crawls all the archives.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2877#comment:6>
