#288: Site Down: Geonetwork on Telascience
Reporter: tmitchell | Owner: sac@lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Component: SAC
Keywords: |
http://www.geonetwork-opensource.org/ is unreachable. It simply timed
out, at my end at least, after 2 minutes of no response. Frank restarted
that server but to no avail - now it just says:
''"Bad Gateway
The proxy server received an invalid response from an upstream server.
Apache/2.0.54 (Fedora) Server at www.geonetwork-opensource.org Port 80
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/288>
OSGeo <http://www.osgeo.org/>
Priority: normal | Component: SAC
Resolution: | Keywords:
Changes (by warmerdam):
* priority: blocker => normal
Comment:
John reports zope was not running and that he has started it. It is
apparently working ok now.
I'm leaving this ticket open, because I think we should somehow update
this system to restart zope automatically on reboot.
I'd add I found the machine in a poor state and I forced a reboot as the
first attempt to fix things.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/288#comment:1>
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by ticheler):
* status: new => closed
* resolution: => fixed
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/288#comment:2>
