#2882: remove download (upload.osgeo.org) from osgeo4 backup routine
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Keywords:
Download is already being fully mirrored on download8 (osgeo8 server).
So that said if anything goes wrong with osgeo7, download8 is already
prepared to take over.
Given that there is no real need for osgeo4 to be backing up download too.
Removing it from the rotation will clear up about 1T of space on osgeo4.
Right now it only has 1T free space for backup.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2882>
OSGeo <Gter - OSGeo;
Component: SysAdmin | Resolution:
Keywords: |
Comment (by strk):
At the moment the /backups/rsync-osgeo7-download.sh script on download8
host is failing, according to the mail sent by Cron Daemon, should I file
a separate ticket for this problem ? Seems related (I found this ticket by
searching for "backup" in the summary)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2882#comment:1>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: SysAdmin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Let's close this out and start a new one. I think I had forgotten to close
this out.
What error are you getting on failing. I know it fails every once in a
while because a qgis file disappears midsyncn and when there is a real
failure there is a constant bombarding of emails.
At glance it seems to be working since I see my latest geos releases on
https://download8.osgeo.org/geos/?C=M&O=D
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2882#comment:2>
