#2883: Setup server on osgeo8 for pgrouting development use
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Keywords:
I will also be adding pgrouting dev team to it.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2883>
OSGeo <Gter - OSGeo;
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I've setup the server, called pgrouting-dev
will add the pgrouting-dev team, once I've registered them on shell group.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2883#comment:1>
OSGeo <https://osgeo.org/>
Keywords: |
Comment (by robe):
Done and added the following to ldap shell and as sudo to the container
robe
cvvergara
krashish8
iosefa
cayetanobv
sanak
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2883#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2883#comment:3>
Keywords: |
Comment (by robe):
Also added RajatShinde and added to sudo and docker groups. The others
mentioned are also in the pgrouting-dev server sudo and docker groups
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2883#comment:4>
