#2894: Update of grass.osgeo.org to Debian 11
Reporter: neteler | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords: debian
At time https://grass.osgeo.org/ is Debian GNU/Linux 10 (buster).
As it is a LXD container I am not sure how an update is to be done.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894>
OSGeo <Gter - OSGeo;
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Resolution:
Keywords: debian |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2023-I
Comment:
It swould follow the same process as any other server, but I can take care
of it if you want.
I think the last upgrade you had done yourself from debian 9 to debian 10.
But given I did run into issues with upgrading some other 10s to 11,
perhaps I should take care of it so I can roll back if issues.
I'll do a trial run on a back up of it on staging, and if looks good I'll
make the change here.
Usually doesn't take more than 2 hrs (of which at most about 1 hr
downtime).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894#comment:1>
OSGeo <https://osgeo.org/>
Keywords: debian |
Comment (by robe):
I did a trial run upgrade of grass with a copy of it using ansible upgrade
script.
It seemed to go fine except somewhere along the line it ended with a dead
PostgreSQL 9.6 and an additional 13 main. pg_lsclusters shows this in my
staging container:
Ver Cluster Port Status Owner Data directory
Log file
9.6 main 5432 down,binaries_missing postgres
/var/lib/postgresql/9.6/main /var/log/postgresql/postgresql-9.6-main.log
11 main 5433 online postgres
/var/lib/postgresql/11/main /var/log/postgresql/postgresql-11-main.log
13 main 5434 online postgres
/var/lib/postgresql/13/main /var/log/postgresql/postgresql-13-main.log
and for current grass:
Ver Cluster Port Status Owner Data directory Log file
11 main 5433 online postgres /var/lib/postgresql/11/main
None of the servers in either has a database on it though aside from the
default databases.
What are you using the postgresql for? Some ci stuff or you don't need it
at all and was installed accidentally perhaps when trying to install just
the clients?
I also see a mysql installed, and again there are no databases in it.
Those are fine to keep, but I'd rather remove services not being used to
minimize issues with future upgrades.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894#comment:2>
Keywords: debian |
Comment (by robe):
I should note there are also some failed services, but I think those might
be an lxd issue and not related to the upgrade.
On upgraded (the grass-staging on osgeo4 which is a copy of prod one) (I
see 4 failed services)
sudo systemctl list-units --state failed
shows:
UNIT LOAD ACTIVE SUB DESCRIPTION
● binfmt-support.service loaded failed failed Enable support for
additional executable binary formats
● systemd-networkd.service loaded failed failed Network Service
● systemd-resolved.service loaded failed failed Network Name
Resolution
● systemd-journald-audit.socket loaded failed failed Journal Audit Socket
● systemd-networkd.socket loaded failed failed Network Service
Netlink Socket
and on grass (current running)
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
I'm pretty sure the current systemd-journal one is some permissions issue
in lxd which I'll investigate.
The one I upgraded, I hadn't checked to see before I started upgrading if
all those were failing. So it might very well be again permission issues
because osgeo4 is running a newer version of Ubuntu (Ubuntu 22.04) v.s
osgeo7 which is still on Ubuntu 20.04.
I'll review these failures before I do the upgrade on grass production.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894#comment:3>
Keywords: debian |
Comment (by neteler):
Thanks for the trials!
The PostgreSQL and mySQL servers can be "brute-force" installed, we only
need them to compile GRASS with those as backends to get the manual pages
for these backends:
https://grass.osgeo.org/grass82/manuals/sql.html
A single (empty) installation of both would be perfect. We may also leave
that out and drop it for now; re-installing them at a later moment to
bring back the manual pages.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894#comment:4>
Keywords: debian |
Comment (by robe):
I checked all the failure in the
Resolution
Netlink Socket
Those all are related to permission issues. It's unclear to me if you
actually need them though. But fix would be to make the container
privileged.
with
lxc config set grass security.nesting=true
That would fix all except the below which is already failing anyway in
prod, so I'll just remove that one.
I'm going to start the upgrade process.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894#comment:5>
Keywords: debian |
Comment (by robe):
Looks like it's still in the middle of upgrade. I should have disabled
cron before I started as it looks like your build job started running and
might be trying to use some python packages it was in middle of upgrading.
I'll let it run for another hour to see if it finishes and if not I'll
kill your running job.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894#comment:6>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: debian |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
I canceled your jobs so I could complete the upgrade. I tried running
your
hugo_clean_and_update_job.sh but get error:
nice: ‘/usr/local/bin/hugo’: No such file or directory
I didn't check if that was missing before or result of changes.
After upgrade following showed as failing, just like they did in staging
● modprobe@drm.service loaded failed failed Load Kernel Module
drm
● systemd-logind.service loaded failed failed User Login Management
Resolution
Netlink Socket
I disabled or masked them so they don't show as failures:
systemctl disable binfmt-support.service
systemctl disable systemd-networkd-wait-online.service
systemctl disable systemd-journald-audit.socket
systemctl mask modprobe@drm.service
systemctl mask systemd-logind.service
systemctl disable systemd-networkd.service
systemctl disable systemd-resolved.service
systemctl mask systemd-journald-audit.socket
systemctl disable systemd-networkd.socket
Can you test out your jobs to make sure they all still work and see if you
see any other issues. Feel free to reopen if you still have issues.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894#comment:7>
Keywords: debian |
Thanks for updating the machine!
The remaining `hugo` issue is now addressed in
https://github.com/OSGeo/grass-addons/pull/875
Will monitor the server for potential other glitches (which I do not
expect).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894#comment:8>
Type: task | Status: reopened
Keywords: debian |
Changes (by neteler):
* status: closed => reopened
* resolution: fixed =>
Comment:
I discovered a problem:
rsync only works from inside the LXD container while from outside:
rsync --dry-run -avz --port=50026 grass.osgeo.org::grass-website grass-
website
rsync: [Receiver] getcwd(): Transport endpoint is not connected (107)
rsync error: errors selecting input/output files, dirs (code 3) at
util1.c(1122) [Receiver=3.2.7]
But a new phenomenon is also this, probably connected?
ssh grasslxd
shell-init: error retrieving current directory: getcwd: cannot access
parent directories: Transport endpoint is not connected
Two days ago (or so) I didn't not get this issue.
Maybe a problem on the jump host?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894#comment:9>
Keywords: debian |
Comment (by robe):
@neteler,
I'm not having an issue.
I did:
website
from one of my servers (not on OSUOSL) and it works fine for me.
could it be maybe a port block issue on yourend?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894#comment:10>
Keywords: debian |
* status: reopened => closed
Comment:
Magic, it also works now from here as well (and ports aren't blocked).
Closing again ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2894#comment:11>
