#290: Subversion Proxies for MapGuide and FDO
Reporter: trevorwekel | Owner: sac@lists.osgeo.org
Priority: normal | Component: SAC
Keywords: |
I would like to set up some external Subversion proxies for the !MapGuide
and FDO Subversion depots. Does anyone have experience using either Squid
or Apache/WebDAV/svnsync?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/290>
OSGeo <http://www.osgeo.org/>
Resolution: | Keywords:
Comment (by warmerdam):
I believe Howard has used svnsync successfully to mirror OSGeo svn
repositories (as live backups). Howard, perhaps you could provide
details? I notice that the use of svnsync for mirroring is not discussed
at all in http://wiki.osgeo.org/wiki/Subversion but likely ought to be.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/290#comment:1>
Comment (by hobu):
What do you mean by proxy? I guess I'm wondering what the usage scenario
is. Is our current setup not serving your needs? Also, for a read-only,
15 minute mirror, did you know about http://svnmirror.osgeo.org/ ?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/290#comment:2>
Comment (by trevorwekel):
Hi Howard,
Ideally, I was looking to set up a read-cache/write-through copy of the
subversion repository closer to the development teams in order to reduce
network usage and improve reponsiveness. For reads, the proxy would cache
the repository contents and serve them locally. For writes, it would
redirect to svn.osgeo.org when the submissions are made. The proxy would
reside behind a firewall so it would have to pull from OsGeo.
I took a quick run at Squid but didn't get very far.
Replying to [comment:2 hobu]:
scenario is. Is our current setup not serving your needs? Also, for a
read-only, 15 minute mirror, did you know about
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/290#comment:3>
Reporter: trevorwekel | Owner: sac@…
Type: enhancement | Status: closed
Priority: normal | Component: Systems Admin
Resolution: fixed | Keywords:
Changes (by crschmidt):
* status: new => closed
* resolution: => fixed
Comment:
I can't imagine that this is going to work well. We've recently greatly
increased the performance of our SVN server by all account; if anyone
still feels a strong need for this, then they can create a new ticket
explaining some of the performacne problems they're seeing, and we can try
to move forward from there.
If you really want a 'local copy' that you can check into, you probably
want something like git-svn or svk instead of an "SVN mirror".
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/290#comment:4>
