#2903: Patch update osgeo6
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Keywords:
Been a while since this was updated.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2903>
OSGeo <Gter - OSGeo;
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Most of versions remain same but just upgrading deb
apache2-bin/oldstable 2.4.38-3+deb10u9 amd64 [upgradable from:
2.4.38-3+deb10u8]
apache2-data/oldstable 2.4.38-3+deb10u9 all [upgradable from:
2.4.38-3+deb10u8]
apache2-doc/oldstable 2.4.38-3+deb10u9 all [upgradable from:
2.4.38-3+deb10u8]
apache2-utils/oldstable 2.4.38-3+deb10u9 amd64 [upgradable from:
2.4.38-3+deb10u8]
apache2/oldstable 2.4.38-3+deb10u9 amd64 [upgradable from:
2.4.38-3+deb10u8]
awstats/oldstable 7.6+dfsg-2+deb10u2 all [upgradable from:
7.6+dfsg-2+deb10u1]
bind9-host/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u8 amd64 [upgradable from:
1:9.11.5.P4+dfsg-5.1+deb10u7]
clamav-base/oldstable 0.103.8+dfsg-0+deb10u1 all [upgradable from:
0.103.6+dfsg-0+deb10u1]
clamav-daemon/oldstable 0.103.8+dfsg-0+deb10u1 amd64 [upgradable from:
clamav-freshclam/oldstable 0.103.8+dfsg-0+deb10u1 amd64 [upgradable from:
clamav/oldstable 0.103.8+dfsg-0+deb10u1 amd64 [upgradable from:
clamdscan/oldstable 0.103.8+dfsg-0+deb10u1 amd64 [upgradable from:
curl/oldstable 7.64.0-4+deb10u5 amd64 [upgradable from: 7.64.0-4+deb10u3]
dbus-user-session/oldstable 1.12.24-0+deb10u1 amd64 [upgradable from:
1.12.20-0+deb10u1]
dbus/oldstable 1.12.24-0+deb10u1 amd64 [upgradable from:
1.12.20-0+deb10u1]
distro-info-data/oldstable 0.41+deb10u6 all [upgradable from:
0.41+deb10u5]
dnsutils/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u8 amd64 [upgradable from:
emacs-bin-common/oldstable 1:26.1+1-3.2+deb10u3 amd64 [upgradable from:
1:26.1+1-3.2+deb10u2]
emacs-common/oldstable 1:26.1+1-3.2+deb10u3 all [upgradable from:
emacs-el/oldstable 1:26.1+1-3.2+deb10u3 all [upgradable from:
emacs-nox/oldstable 1:26.1+1-3.2+deb10u3 amd64 [upgradable from:
emacs/oldstable 1:26.1+1-3.2+deb10u3 all [upgradable from:
gdal-bin/oldstable 2.4.0+dfsg-1+deb10u1 amd64 [upgradable from:
2.4.0+dfsg-1+b1]
gdal-data/oldstable 2.4.0+dfsg-1+deb10u1 all [upgradable from:
2.4.0+dfsg-1]
git-man/oldstable 1:2.20.1-2+deb10u8 all [upgradable from:
1:2.20.1-2+deb10u3]
git/oldstable 1:2.20.1-2+deb10u8 amd64 [upgradable from:
1:2.20.1-2+deb10u3]
gnutls-bin/oldstable 3.6.7-4+deb10u10 amd64 [upgradable from:
3.6.7-4+deb10u9]
grub-common/oldstable 2.06-3~deb10u3 amd64 [upgradable from:
2.06-3~deb10u1]
grub-pc-bin/oldstable 2.06-3~deb10u3 amd64 [upgradable from:
2.06-3~deb10u1]
grub-pc/oldstable 2.06-3~deb10u3 amd64 [upgradable from: 2.06-3~deb10u1]
grub2-common/oldstable 2.06-3~deb10u3 amd64 [upgradable from:
2.06-3~deb10u1]
isc-dhcp-client/oldstable 4.4.1-2+deb10u3 amd64 [upgradable from:
4.4.1-2+deb10u1]
isc-dhcp-common/oldstable 4.4.1-2+deb10u3 amd64 [upgradable from:
4.4.1-2+deb10u1]
krb5-locales/oldstable 1.17-3+deb10u5 all [upgradable from:
1.17-3+deb10u4]
libaprutil1-dbd-sqlite3/oldstable 1.6.1-4+deb10u1 amd64 [upgradable from:
1.6.1-4]
libaprutil1-ldap/oldstable 1.6.1-4+deb10u1 amd64 [upgradable from:
1.6.1-4]
libaprutil1/oldstable 1.6.1-4+deb10u1 amd64 [upgradable from: 1.6.1-4]
libarchive-tools/oldstable 3.3.3-4+deb10u3 amd64 [upgradable from:
3.3.3-4+deb10u1]
libarchive13/oldstable 3.3.3-4+deb10u3 amd64 [upgradable from:
3.3.3-4+deb10u1]
libavcodec58/oldstable 7:4.1.10-0+deb10u1 amd64 [upgradable from:
7:4.1.9-0+deb10u1]
libavformat58/oldstable 7:4.1.10-0+deb10u1 amd64 [upgradable from:
7:4.1.9-0+deb10u1]
libavutil56/oldstable 7:4.1.10-0+deb10u1 amd64 [upgradable from:
7:4.1.9-0+deb10u1]
libbind9-161/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u8 amd64 [upgradable
libbluray2/oldstable 1:1.1.0-1+deb10u1 amd64 [upgradable from: 1:1.1.0-1]
libc-bin/oldstable 2.28-10+deb10u2 amd64 [upgradable from:
2.28-10+deb10u1]
libc-dev-bin/oldstable 2.28-10+deb10u2 amd64 [upgradable from:
2.28-10+deb10u1]
libc-l10n/oldstable 2.28-10+deb10u2 all [upgradable from: 2.28-10+deb10u1]
libc6-dev/oldstable 2.28-10+deb10u2 amd64 [upgradable from:
2.28-10+deb10u1]
libc6/oldstable 2.28-10+deb10u2 amd64 [upgradable from: 2.28-10+deb10u1]
libclamav9/oldstable 0.103.8+dfsg-0+deb10u1 amd64 [upgradable from:
libcurl3-gnutls/oldstable 7.64.0-4+deb10u5 amd64 [upgradable from:
7.64.0-4+deb10u3]
libcurl4-gnutls-dev/oldstable 7.64.0-4+deb10u5 amd64 [upgradable from:
7.64.0-4+deb10u3]
libcurl4/oldstable 7.64.0-4+deb10u5 amd64 [upgradable from:
7.64.0-4+deb10u3]
libdbus-1-3/oldstable 1.12.24-0+deb10u1 amd64 [upgradable from:
1.12.20-0+deb10u1]
libdns-export1104/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u8 amd64 [upgradable
libdns1104/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u8 amd64 [upgradable from:
libexpat1-dev/oldstable 2.2.6-2+deb10u6 amd64 [upgradable from:
2.2.6-2+deb10u4]
libexpat1/oldstable 2.2.6-2+deb10u6 amd64 [upgradable from:
2.2.6-2+deb10u4]
libgdal-dev/oldstable 2.4.0+dfsg-1+deb10u1 amd64 [upgradable from:
2.4.0+dfsg-1+b1]
libgdal20/oldstable 2.4.0+dfsg-1+deb10u1 amd64 [upgradable from:
2.4.0+dfsg-1+b1]
libgif-dev/oldstable 5.1.4-3+deb10u1 amd64 [upgradable from: 5.1.4-3]
libgif7/oldstable 5.1.4-3+deb10u1 amd64 [upgradable from: 5.1.4-3]
libgnutls-dane0/oldstable 3.6.7-4+deb10u10 amd64 [upgradable from:
3.6.7-4+deb10u9]
libgnutls-openssl27/oldstable 3.6.7-4+deb10u10 amd64 [upgradable from:
3.6.7-4+deb10u9]
libgnutls28-dev/oldstable 3.6.7-4+deb10u10 amd64 [upgradable from:
3.6.7-4+deb10u9]
libgnutls30/oldstable 3.6.7-4+deb10u10 amd64 [upgradable from:
3.6.7-4+deb10u9]
libgnutlsxx28/oldstable 3.6.7-4+deb10u10 amd64 [upgradable from:
3.6.7-4+deb10u9]
libgssapi-krb5-2/oldstable 1.17-3+deb10u5 amd64 [upgradable from:
1.17-3+deb10u4]
libhttp-daemon-perl/oldstable 6.01-3+deb10u1 all [upgradable from: 6.01-3]
libirs161/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u8 amd64 [upgradable from:
libisc-export1100/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u8 amd64 [upgradable
libisc1100/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u8 amd64 [upgradable from:
libisccc161/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u8 amd64 [upgradable from:
libisccfg163/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u8 amd64 [upgradable
libjs-jquery-ui/oldstable 1.12.1+dfsg-5+deb10u1 all [upgradable from:
1.12.1+dfsg-5]
libk5crypto3/oldstable 1.17-3+deb10u5 amd64 [upgradable from:
1.17-3+deb10u4]
libkrb5-3/oldstable 1.17-3+deb10u5 amd64 [upgradable from: 1.17-3+deb10u4]
libkrb5support0/oldstable 1.17-3+deb10u5 amd64 [upgradable from:
1.17-3+deb10u4]
libksba8/oldstable 1.3.5-2+deb10u2 amd64 [upgradable from: 1.3.5-2]
liblwres161/oldstable 1:9.11.5.P4+dfsg-5.1+deb10u8 amd64 [upgradable from:
libmariadb-dev-compat/oldstable 1:10.3.38-0+deb10u1 amd64 [upgradable
libmariadb-dev/oldstable 1:10.3.38-0+deb10u1 amd64 [upgradable from:
1:10.3.36-0+deb10u1]
libmariadb3/oldstable 1:10.3.38-0+deb10u1 amd64 [upgradable from:
libncurses-dev/oldstable 6.1+20181013-2+deb10u3 amd64 [upgradable from:
6.1+20181013-2+deb10u2]
libncurses5-dev/oldstable 6.1+20181013-2+deb10u3 amd64 [upgradable from:
libncurses5/oldstable 6.1+20181013-2+deb10u3 amd64 [upgradable from:
libncurses6/oldstable 6.1+20181013-2+deb10u3 amd64 [upgradable from:
libncursesw5/oldstable 6.1+20181013-2+deb10u3 amd64 [upgradable from:
libncursesw6/oldstable 6.1+20181013-2+deb10u3 amd64 [upgradable from:
libnss3/oldstable 2:3.42.1-1+deb10u6 amd64 [upgradable from:
2:3.42.1-1+deb10u5]
libopenexr23/oldstable 2.2.1-4.1+deb10u2 amd64 [upgradable from:
2.2.1-4.1+deb10u1]
libpcre2-16-0/oldstable 10.32-5+deb10u1 amd64 [upgradable from: 10.32-5]
libpcre2-8-0/oldstable 10.32-5+deb10u1 amd64 [upgradable from: 10.32-5]
libpixman-1-0/oldstable 0.36.0-1+deb10u1 amd64 [upgradable from: 0.36.0-1]
libpixman-1-dev/oldstable 0.36.0-1+deb10u1 amd64 [upgradable from:
0.36.0-1]
libpoppler-dev/oldstable 0.71.0-5+deb10u1 amd64 [upgradable from:
0.71.0-5]
libpoppler-private-dev/oldstable 0.71.0-5+deb10u1 amd64 [upgradable from:
0.71.0-5]
libpoppler-qt5-1/oldstable 0.71.0-5+deb10u1 amd64 [upgradable from:
0.71.0-5]
libpoppler82/oldstable 0.71.0-5+deb10u1 amd64 [upgradable from: 0.71.0-5]
libpython3.7-dev/oldstable 3.7.3-2+deb10u4 amd64 [upgradable from:
3.7.3-2+deb10u3]
libpython3.7-minimal/oldstable 3.7.3-2+deb10u4 amd64 [upgradable from:
3.7.3-2+deb10u3]
libpython3.7-stdlib/oldstable 3.7.3-2+deb10u4 amd64 [upgradable from:
3.7.3-2+deb10u3]
libpython3.7/oldstable 3.7.3-2+deb10u4 amd64 [upgradable from:
3.7.3-2+deb10u3]
libraw19/oldstable 0.19.2-2+deb10u2 amd64 [upgradable from:
0.19.2-2+deb10u1]
libsndfile1/oldstable 1.0.28-6+deb10u2 amd64 [upgradable from:
1.0.28-6+deb10u1]
libsnmp-base/oldstable 5.7.3+dfsg-5+deb10u4 all [upgradable from:
5.7.3+dfsg-5+deb10u3]
libsnmp30/oldstable 5.7.3+dfsg-5+deb10u4 amd64 [upgradable from:
libssl-dev/oldstable 1.1.1n-0+deb10u4 amd64 [upgradable from:
1.1.1n-0+deb10u3]
libssl1.1/oldstable 1.1.1n-0+deb10u4 amd64 [upgradable from:
1.1.1n-0+deb10u3]
libswresample3/oldstable 7:4.1.10-0+deb10u1 amd64 [upgradable from:
7:4.1.9-0+deb10u1]
libswscale5/oldstable 7:4.1.10-0+deb10u1 amd64 [upgradable from:
7:4.1.9-0+deb10u1]
libtasn1-6-dev/oldstable 4.13-3+deb10u1 amd64 [upgradable from: 4.13-3]
libtasn1-6/oldstable 4.13-3+deb10u1 amd64 [upgradable from: 4.13-3]
libtasn1-doc/oldstable 4.13-3+deb10u1 all [upgradable from: 4.13-3]
libtiff-dev/oldstable 4.1.0+git191117-2~deb10u7 amd64 [upgradable from:
4.1.0+git191117-2~deb10u4]
libtiff5/oldstable 4.1.0+git191117-2~deb10u7 amd64 [upgradable from:
libtiffxx5/oldstable 4.1.0+git191117-2~deb10u7 amd64 [upgradable from:
libtinfo5/oldstable 6.1+20181013-2+deb10u3 amd64 [upgradable from:
libtinfo6/oldstable 6.1+20181013-2+deb10u3 amd64 [upgradable from:
libxapian30/oldstable 1.4.11-1+deb10u1 amd64 [upgradable from: 1.4.11-1]
libxml2-dev/oldstable 2.9.4+dfsg1-7+deb10u5 amd64 [upgradable from:
2.9.4+dfsg1-7+deb10u4]
libxml2/oldstable 2.9.4+dfsg1-7+deb10u5 amd64 [upgradable from:
linux-libc-dev/oldstable 4.19.269-1 amd64 [upgradable from: 4.19.249-2]
locales-all/oldstable 2.28-10+deb10u2 amd64 [upgradable from:
2.28-10+deb10u1]
locales/oldstable 2.28-10+deb10u2 all [upgradable from: 2.28-10+deb10u1]
mariadb-client-10.3/oldstable 1:10.3.38-0+deb10u1 amd64 [upgradable from:
mariadb-client-core-10.3/oldstable 1:10.3.38-0+deb10u1 amd64 [upgradable
mariadb-common/oldstable 1:10.3.38-0+deb10u1 all [upgradable from:
mariadb-server-10.3/oldstable 1:10.3.38-0+deb10u1 amd64 [upgradable from:
mariadb-server-core-10.3/oldstable 1:10.3.38-0+deb10u1 amd64 [upgradable
multiarch-support/oldstable 2.28-10+deb10u2 amd64 [upgradable from:
2.28-10+deb10u1]
ncurses-base/oldstable 6.1+20181013-2+deb10u3 all [upgradable from:
ncurses-bin/oldstable 6.1+20181013-2+deb10u3 amd64 [upgradable from:
ncurses-term/oldstable 6.1+20181013-2+deb10u3 all [upgradable from:
nscd/oldstable 2.28-10+deb10u2 amd64 [upgradable from: 2.28-10+deb10u1]
openssl/oldstable 1.1.1n-0+deb10u4 amd64 [upgradable from:
1.1.1n-0+deb10u3]
postgresql-11/oldstable 11.19-0+deb10u1 amd64 [upgradable from:
11.17-0+deb10u1]
postgresql-client-11/oldstable 11.19-0+deb10u1 amd64 [upgradable from:
11.17-0+deb10u1]
python-cryptography/oldstable 2.6.1-3+deb10u4 amd64 [upgradable from:
2.6.1-3+deb10u2]
python-joblib/oldstable 0.13.0-2+deb10u1 all [upgradable from: 0.13.0-2]
python3-cryptography/oldstable 2.6.1-3+deb10u4 amd64 [upgradable from:
2.6.1-3+deb10u2]
3.7.3-2+deb10u3]
3.7.3-2+deb10u3]
3.7.3-2+deb10u3]
sudo/oldstable 1.8.27-1+deb10u5 amd64 [upgradable from: 1.8.27-1+deb10u3]
sysstat/oldstable 12.0.3-2+deb10u1 amd64 [upgradable from: 12.0.3-2]
tmux/oldstable 2.8-3+deb10u1 amd64 [upgradable from: 2.8-3]
tzdata/oldstable 2021a-0+deb10u10 all [upgradable from: 2021a-0+deb10u6]
unzip/oldstable 6.0-23+deb10u3 amd64 [upgradable from: 6.0-23+deb10u2]
vim-common/oldstable 2:8.1.0875-5+deb10u4 all [upgradable from:
2:8.1.0875-5+deb10u2]
vim-runtime/oldstable 2:8.1.0875-5+deb10u4 all [upgradable from:
vim-tiny/oldstable 2:8.1.0875-5+deb10u4 amd64 [upgradable from:
vim/oldstable 2:8.1.0875-5+deb10u4 amd64 [upgradable from:
xxd/oldstable 2:8.1.0875-5+deb10u4 amd64 [upgradable from:
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2903#comment:1>
OSGeo <https://osgeo.org/>
