#2907: Wikimedia replace for libavatar
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Keywords:
As noted in #2896 I had to remove our libavatar plugin for mediawiki as it
doesn't work for mediawiki 1.35 and above and the mediawiki 1.34 we were
on has reached EOL.
That said I had installed Gravatar instead, but strk said there are issues
with that as it will send traffic to Gravatar.com.
https://www.mediawiki.org/wiki/Extension:Gravatar
It says it can use the libavatar service but didn't research enough to see
how to do that.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2907>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Description changed by robe:
Old description:
it doesn't work for mediawiki 1.35 and above and the mediawiki 1.34 we
were on has reached EOL.
issues with that as it will send traffic to Gravatar.com.
see how to do that.
New description:
on has reached EOL.
https://www.mediawiki.org/wiki/Extension:Libravatar
how to do that.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2907#comment:1>
Keywords: |
Comment (by robe):
Reading thru the docs, it seems we can define a
$wgGravatarServer
in our settings to point at a libavatar service?
I don't know what to set that to.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2907#comment:2>
Keywords: |
Comment (by strk):
Libravatar was requested with #1688 (for the record).
I left a request to bring the Libravatar back to life in
https://www.mediawiki.org/w/index.php?title=Extension_talk%3ALibravatar#We’d_like_to_bring_this_back_to_life
Can you try setting that variable to libravatar.org for a start ? Ideally
we'd run our own libravatar service, so to not send all traffic to
libravatar.org, but until then, libravatar.org is a tad better than
gravatar.com, if not else it should be already looking up DNS and thus
allowing us to serve our avatars from a server of our choice.
Beside the variable I guess when we do that we'd also want to leave a note
to users about what they are REALLY enabling with the relevant checkbox in
https://wiki.osgeo.org/wiki/Special:Preferences
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2907#comment:3>
Keywords: |
Comment (by strk):
I was wrong, pointing to the libravatar "bird site" won't implement the
DNS lookup, so the only real way to support DNS lookups would be having
our own DNS-looking cache server
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2907#comment:4>
