#2911: Installation of engelsystem for FOSS4G 2023
Reporter: astrid_emde | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
- Engelsystem - online tool for coordinating helpers and work shifts on large events
- could you please install engelsystem (a platform to coordinate the help
team at the conference and create shifts)
- we would like to try it for FOSS4G 2023
- for every conference we would need a new installation of the system (or
a new fresh database)
- link could be something like https://2023-engel.foss4g.org or
https://2023.engelsystem.org or as you like
- please provide the credentials to me. I will configure the system and
share it with the FOSS4G team
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911>
OSGeo <Gter - OSGeo;
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Resolution:
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2023-I
Comment:
Okay will take a look at this today and if no issues try to get up this
week.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:1>
OSGeo <https://osgeo.org/>
Keywords: |
Comment (by astrid_emde):
thanks a lot
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:2>
Keywords: |
Comment (by robe):
I have the docker built on staging, but still trying to work out the
proxying cause the assets are all being served via http instead of https,
which is causing things like css not to load.
It's supposed to be the TRUSTED_PROXIES but that all looks okay to me,
though I think it's not reading it.
https://engelsystem.staging.osgeo.org/
once I have that sorted out, I'll deploy it on the pretalx server and call
it
I currently have the docker build based on the main branch, but perhaps I
should go with a tagged one -
https://github.com/engelsystem/engelsystem/releases/tag/v3.3.0 which is
Dec 2021.
astride you know which is the best to go with?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:3>
Keywords: |
Comment (by robe):
I think I have the proxy issue sorted out, needed to define an APP_URL in
the docker/deployment.env which has https:// in it.
Also had to revise the docker/nginx.conf to have remote_ip_from
set_real_ip_from 127.0.0.1;
set_real_ip_from 10.0.0.0/8;
#set_real_if_from nginx.lxd;
real_ip_recursive on;
for it to return the real ips. Not sure why the TRUSTED_PROXIES I defined
is not used.
Also had to add to the Dockerfile, a restart: always as it wasn't
restarting on server reboot.
https://forums.docker.com/t/how-to-handle-server-reboot-when-using-
docker-compose/26374/3
astride - I just emailed you the login. Can you test out and see if it is
good enough to deploy or if any changes needed. I'm using the main branch
rather than a tagged version.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:4>
Keywords: |
HI @robe, thanks for the access. It works fine. Thequestio from the FOSS4G
team is whether they could get root access for the production server to
have access to the logs and database.
If this is not possible they could install it independently on theier
servers. Looks like it would not be a problem.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:5>
Keywords: |
Comment (by robe):
Replying to [comment:5 astrid_emde]:
FOSS4G team is whether they could get root access for the production
server to have access to the logs and database.
No issue with giving them access. They just need an OSGeo account and
then I can give them shell access and give them sudo rights to that
server.
To be safe, I should probably put it on a different server from pretalx
that way if they need to reboot or anything it will only be affecting this
server. I assume that is okay?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:6>
Keywords: |
Comment (by robe):
I've copied it over to osgeo8 host and have a dedicated instance for it.
If you give me their osgeo user names, I can give them root access to it.
The production url is:
Same admin and password as I sent you.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:7>
Keywords: |
Thanks a lot again. I will ask for their OSGeo-Ids
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:8>
Keywords: |
Comment (by DLange):
Could you please create login users on osgeo8-engelsystem for
* DLange
* Enkelenaflossk
and give us sudo rights as well?\\
Thank you.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:9>
Keywords: |
Comment (by robe):
I've given both accounts sudo rights:
To use, make sure you have your public key registered on your accounts:
https://id.staging.osgeo.org/ldap/edit
and then you should be able to follow rules here:
https://wiki.osgeo.org/wiki/SAC_Service_Status#Logging_into_LXD_Containers_and_VMs
So doing the below should get you in (replacing robe with your user name)
and once in you should be able to do sudo whatever
ssh robe@osgeo8-engelsystem
Let me know if you need any help.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:10>
Keywords: |
Comment (by robe):
One slight note, you will get a password prompt for second, (since the
first pass is for the jump host). You can add your key manually once you
are in to avoid the password prompt in future.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:11>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
I've reset a fresh ubuntu 22.04 from osgeo-ldap template and moved it to
osgeo9
DLange has resetup englesystem on bare system and provided me with his
instructions for future maintenance or if we want to use it for other
conferences. I've logged these on the osgeo9
https://git.osgeo.org/gitea/sac/osgeo9/wiki/engelsystem.
I also setup a engelsystem@foss4g.org alias in PairsDomain with Daniel and
Enkelenaflossk which DLange is using for sending and receiving emails from
the engelsystem.
Backup is set to go to osgeo4 as well.
That said I think this is done.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2911#comment:12>
