#2914: cannot access 'mapserver' OSGeo7 container after reboot
Reporter: Jeff McKenna | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
- logged into 'mapserver' container on osgeo7 (through usual
proxyjump/hop)
- rebooted 'mapserver' container
- system didn't seem to come up (as https://demo.mapserver.org also isn't
available)
- now cannot login to 'mapserver' container
- however I can login/hop onto other containers
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2914>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
* milestone: Unplanned => Sysadmin Contract 2023-I
Comment:
For some reason it didn't start back up on it's own.
After starting it I ran:
apt update
apt upgrade
reboot
Looks like it also installed php8.2 for some reason, and updated PHP 8.1.
But it did come back on it's own this time and demo site is up.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2914#comment:1>
Keywords: |
Comment (by robe):
I also noticed systemctl status showed degraded and sudo systemctl list-
units --state failed showed below failed
systemd-journald-audit.socket
so I disabled these, same ones that cause issues with bullseye (just in
case)
systemctl disable binfmt-support.service
systemctl disable systemd-networkd-wait-online.service
systemctl disable systemd-journald-audit.socket
systemctl mask modprobe@drm.service
systemctl mask systemd-logind.service
systemctl disable systemd-networkd.service
systemctl disable systemd-resolved.service
systemctl mask systemd-journald-audit.socket
systemctl disable systemd-networkd.socket
and then rebooted again. Came back fine.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2914#comment:2>
Keywords: |
Comment (by Jeff McKenna):
Thank-you for tackling this @robe, really appreciated. (all's well again)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2914#comment:3>
