#2920: www.osgeo.org (wordpress): saving of edits leads to critical error
Reporter: neteler | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords: wordpress
I tried to update the actinia page but after editing I got:
Log In ‹ OSGeo — WordPress
There has been a critical error on this website. Please check your site
admin email inbox for instructions.
Learn more about troubleshooting WordPress.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920>
OSGeo <Gter - OSGeo;
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Resolution:
Keywords: wordpress |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2023-I
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:1>
OSGeo <https://osgeo.org/>
Comment (by robe):
What were you updating on actinia page? I just clicked update on actinia
page and received no error. Also editing postgis page and got no error.
I thought there was a log within wordpress that showed errors, but can't
find it.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:2>
Comment (by neteler):
I had updated various links (all github moved from github.com/mundialis/
ORG to github.com/actinia-org/ and others, too.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:3>
Comment (by robe):
I was able to update the github links that had mundialis to actinia-org
with no error. So perhaps some sort of permission issue or browser cache
issue.
Can you clear out your browser cache and then try updating again.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:4>
Thanks for having updated the links.
I eventually nailed it down:
Adding a new member under "Select members that are involved in this
project." it leads to above error.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:5>
Comment (by robe):
Still can't replicate. I added myself to the project and that completed
fine, and then removed myself. Also fine. I did the same with PostGIS.
Maybe specific to the person you were adding?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:6>
Comment (by robe):
@neteler are you still having this issue?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:7>
I don't find the section "Select members that are involved in this
project." any more for the actinia community project, so no idea how to
edit that.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:8>
Comment (by robe):
It's in the About section - "Who's involved". I thought it used to be a
separate tab on it's own at one point, but I could be mistaken
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:9>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Changes (by neteler):
* status: new => closed
* resolution: => fixed
Comment:
Thanks, found it in the "About" tab.
And success, I was able to edit and save. Problem gone.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:10>
Type: task | Status: reopened
Priority: normal | Milestone: Sysadmin Contract 2023-II
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
* milestone: Sysadmin Contract 2023-I => Sysadmin Contract 2023-II
Comment:
As discussed with neteler offlist, he is still having an issue adding a
specific user.
The error I am seeing in the log email is -
An error of type E_ERROR was caused in line 207 of the file
/var/www/osgeo.org/httpdocs/wp-content/themes/roots/lib/custom.php. Error
message: Uncaught Error: operator not supported for strings in
/var/www/osgeo.org/httpdocs/wp-content/themes/roots/lib/custom.php:207
Stack trace:
#0 /var/www/osgeo.org/httpdocs/core/wp-includes/class-wp-hook.php(308):
syncUsersForProject()
#1 /var/www/osgeo.org/httpdocs/core/wp-includes/class-wp-hook.php(332):
WP_Hook->apply_filters()
Why it's only an issue for trying to add this specific user I'm not sure,
but I think the code in our theme needs to be changed in our custom theme.
Vicky I'm reassigning to you since you have more experience with the php
side of this.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:11>
Comment (by cvvergara):
I could add my self,
Who are we trying to add?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:12>
I'll send the name off-trac to you.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:13>
About adding the contributor to actinia:
Change on Project:
* Who's involved: added the contributor
List of tests done
**test 1**
Change on profile:
* Name: was blank -> added the name
* After adding the contributor **FAIL**
**test 2**
Change on profile:
* Project Contributor: -> added actinia
* (with or without name)
* After adding the contributor **SUCCESS**
Same problem on dev.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2920#comment:14>
Component: SysAdmin | Resolution: fixed
Changes (by cvvergara):
* status: reopened => closed
Comment:
Made the tests again, I did not have the problems.
Maybe was solved when updating WordPress
Ticket URL: <#2920 (www.osgeo.org (wordpress): saving of edits leads to critical error) – OSGeo;
