#2921: Make gitea official url be gitea.osgeo.org
Reporter: strk | Owner: strk
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Gitea | Keywords:
And drop a redirect from git.osgeo.org/gitea to gitea.osgeo.org
The reason for using the subdir was a least-change approach to
infrastructure. Nowadays it looks like we are more flexible in how we do
things...
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2921>
OSGeo <Gter - OSGeo;
Component: Gitea | Resolution:
Keywords: |
Comment (by lnicola):
Should we stick to git.osgeo.org? That way it might still work if we ever
switch from Gitea to whatever fork gets popular next.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2921#comment:1>
OSGeo <https://osgeo.org/>
Keywords: |
Comment (by robe):
I'm thinking that too that we should just call it git.osgeo.org. That way
my SSH won't change too.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2921#comment:2>
Keywords: |
Comment (by strk):
There are distinct configuration directives for the SSH host and the HTTP
base url so you don't need to change the SSH remote.
And we have HTTP redirects so there's no urge to change your HTTP remote
either (git.osgeo.org/gogs still work as a remote). For the same reason
shall we move to another hoster we'll still be able to use redirects so I
continue thinking gitea.osgeo.org is a good name. The git.osgeo.org url
could still redirect there as it does now (possibly in a direct way)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2921#comment:3>
Keywords: |
Comment (by robe):
I suppose since we have gitea.osgeo.org already working it's okay to keep
it.
I don't think the redirect thing is that seamless though. Like I'm sure
weblate will complain if I don't change the postgis links to the
gitea.osgeo.org cause I recall it not liking redirects.
So I'm just a little concerned of the services we have that might break. I
suppose if things go bad it would be just flipping the switch from
gitea.osgeo.org back to git.osgeo.org/gitea.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2921#comment:4>
Priority: normal | Milestone: Sysadmin Contract 2024-III
Component: SysAdmin/Gitea | Resolution:
Keywords: |
Changes (by strk):
* milestone: Unplanned => Sysadmin Contract 2024-III
Comment:
Moving gitea install to root-path will also have the benefit of making
webfinger work, which is currently broken:
- WebFinger
- WebFinger
Laurențiu see also the webfinger implications in the name, would you want
it to be lnicola@git.osgeo.org or lnicola@gitea.osgeo.org to follow your
activity in the osgeo git hoster ? And let's also consider the case in
which we want to test another git hoster, which happened in the past (we
tested gitlab)
See how webfinger works on the gitea.com deploy:
- WebFinger
Ticket URL: <#2921 (Make gitea official url be gitea.osgeo.org) – OSGeo;
Keywords: |
I'd prefer lnicola@osgeo.org or lnicola@git.osgeo.org. If you decide you
like Forgejo more, the URLs can stay unchanged.
Keywords: |
Lol, osgeo.org or git.osgeo.org.
Keywords: |
Comment (by strk):
The problem I see with @osgeo.org is that there are different "facets" of
you, so I might want to follow the "gitea committer" facet of you while
not following the "video poster" or "photo poster" you.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2921#comment:8>
Keywords: |
Yeah, that's understandable. git.osgeo.org is fine.
Keywords: |
Comment (by strk):
We settled with lnicola (on #sac:osgeo.org) about:
- git.osgeo.org becoming a redirect to gitea.osgeo.org (instead of
git.osgeo.org/gitea)
- gitea.osgeo.org becoming the official url of the Gitea OSGeo service
Keywords: |
Comment (by robe):
I'm just worried how much stuff is going to break, but I guess the longer
we wait the more painful the break.
So I guess our sshs will all be git@gitea.osgeo.org though I imagine
git@git.osgeo.org will still work right?
Keywords: |
Comment (by strk):
You can test right now if git@gitea.osgeo.org works as a remote. It works
for me:
$ git config remote.origin.url git@gitea.osgeo.org:sac/ansible-
deployment.git
$ git fetch origin
$ git config remote.origin.url git@git.osgeo.org:sac/ansible-
deployment.git
$ git fetch origin
I didn't change any official names
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2921#comment:12>
Keywords: |
Comment (by strk):
Regina is there a procedure to re-create the gitea staging container from
the production one ? I'd like to test the configuration change but
currently staging is using a newer version of Gitea which is incompatible
with both the database and the configuration we're using
Keywords: |
Comment (by robe):
Replying to [comment:12 strk]:
works for me:
deployment.git
> $ git fetch origin
deployment.git
> $ git fetch origin
Yah it should work since gitea.osgeo.org points at the same ip and port 22
for the secondary ip is allocated for tracsvn.
Regarding the redeploy of tracsvn, if you don't care about data, you
should be able to roll it back before I upgraded by doing
lxc restore tracsvn-dev reset
I just did that but something is wrong - it is now at what production was
so should be the same version, but the login page is giving me a can't
load asset thing. I'm assuming that is something in your new staging
script?
I just did that so should be the same version as production now.
But to build direct from production backup, that's a bit more involved
You have to completely delete the container first and then run thru
deployment/roles/staging/tasks/build-tracsvn-dev.yml
I usually have to run it twice cause of some sequencing issue.
Keywords: |
Comment (by strk):
Ok the gitea configuration was now deployed via ansible for both staging
and production environments, using this:
ANSIBLE_CONFIG=ansible.osgeo.staging.cfg ansible-playbook deployment
/deploy-gitea.yml
ANSIBLE_CONFIG=ansible.osgeo.prod.cfg ansible-playbook deployment/deploy-
gitea.yml
Each run deployed to 2 different hosts, as per inventory:
- The one running Gitea (osgeo3-tracsvn, osgeo4-tracsvn-dev)
- The one running ngnix proxy (osgeo4-nginx, osgeo7-nginx)
But the role is not yet full because a staging domain is missing for the
gitea.osgeo.org.
As discussed on IRC it could be a good idea to have all staging domains
fall under the "dev.osgeo.org" (or "stage.osgeo.org" which is longer but
matches the scope more).
I'll let you decide but at the end we need:
git.<stage>.osgeo.org
gitea.<stage>.osgeo.org
Doing that via ansible (see #3188) would be great but I will not wait on
that.
