#2926: Fix forward secrecy on osgeo9
Reporter:  robe           |      Owner:  sac@…
     Type:  task           |     Status:  new
Priority:  normal         |  Milestone:  Sysadmin Contract 2023-I
Component:  Systems Admin  |   Keywords:
osgeo9 server is getting a B score on SSLabs because of the forward
secrecy setting
https://blog.qualys.com/product-tech/2018/02/02/forward-secrecy-
authenticated-encryption-and-robot-grading-
update?_ga=2.93270165.907080469.1682616254-892586743.1682616254
This affects all websites on osgeo9.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2926>
OSGeo <https://osgeo.org/>
              #2926: Fix forward secrecy on osgeo9 and osgeo8
     Type:  task           |      Status:  closed
Component:  Systems Admin  |  Resolution:  fixed
Keywords:                 |
Changes (by robe):
* status:  new => closed
* resolution:   => fixed
* summary:  Fix forward secrecy on osgeo9 => Fix forward secrecy on osgeo9
     and osgeo8
Comment:
Was an issue on both osgeo8 and osgeo9. Had to add this line to the
/etc/nginx/nginx.conf
as noted in https://www.digicert.com/kb/ssl-support/ssl-enabling-perfect-
forward-secrecy.htm
ssl_ciphers "EECDH+ECDSA+AESGCM EECDH+aRSA+AESGCM EECDH+ECDSA+SHA384
EECDH+ECDSA+SHA256 EECDH+aRSA+SHA384 EECDH+aRSA+SHA256 EECDH+aRSA+RC4
EECDH EDH+aRSA RC4 !aNULL !eNULL !LOW !3DES !MD5 !EXP !PSK !SRP !DSS";
osgeo7 nginx doesn't have a ssl_ciphers setting yet it seems to be fine,
so must be the defaults on nginx/1.18.0 (ubuntu) which is what osgeo7 is
running vs. the nginx/1.18.0 (Debian bullseye) defaults are different and
the ubuntu one is stricter.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2926#comment:1>
