#2939: Render jupyter notebooks in html in gitea
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
Per request of darkblueb.
Steps more or less detailed here - https://blog.gitea.io/2022/04/how-to-
render-jupyter-notebooks-on-gitea/
But had to install ipython as well so:
sudo apt install python3-pip
pip3 install nbconvert
pip3 install ipython
and then added in the respective lines.
But I think I need to do somethng to enable css and strip the html cause
it looks funny.
You can see an example here:
https://dev.git.osgeo.org/gitea/osgeolive/OSGeoLive-
Notebooks/src/branch/master/Shapely/shapely-point-in-poly.ipynb
There is also other things like rendering mathjax as detailed in this
thread
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2939>
OSGeo <Gter - OSGeo;
