#2946: Upgrade nextcloud from 25.03 to 25.0.8
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Keywords:
The nextcloud is several security patches behind.
Also it seems the office server export to PDF is broken.
Same issue as last time -
PDF prints are blank - Document Server cant print any fonts · Issue #251 · nextcloud/documentserver_community · GitHub
Last time this happened I did
apt install ttf-mscorefonts-installer
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2946>
OSGeo <Gter - OSGeo;
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2946#comment:1>
OSGeo <https://osgeo.org/>
Keywords: |
Comment (by robe):
issue with pdf export is still unfixed though.
In Nextcloud 26, they removed the documentserver/onlyoffice we were using.
Going to check if they have a good replacement before attempting upgrade
to 26 and will do that in dev first.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2946#comment:2>
