I would need to resurrect the box they are on and mount it on the network. It''s a pretty old machine and is occasionally shutting down from overheating, etc.
I'll get that working first before trying anything. I may just replace it, and use it as a backup for all the videos. I've been meaning to do this anyway, now I have a reason. I also have most everything in dropbox, but that are not organized really well there.
Bobb
FY5HWX3(new)
PW19-S295-C024 (old)
> > -----Original Message-----
> > From: Sac <sac-bounces@lists.osgeo.org> On Behalf Of Regina Obe
> > Sent: Wednesday, August 2, 2023 1:00 PM
> > To: 'System Administration Committee Discussion/OSGeo'
> > <sac@lists.osgeo.org>
> > Subject: Re: [SAC] [OSGeo] #2959: Help getting FOSS4G 2022 videos into
> > video.osgeo.org and FOSS4G youtube channel
> > Think Before You Click: This email originated outside our organization.
> > Bob,
> > Okay that would be great. Maybe you can be a guinea pig to experiment
> > with the using the cli upload.
> > I've never used the cli before to pull in the videos.
> > Although if you have these as urls already, might be doable to use the
> > built in feature to pull in by url.
> > > From: Sac [mailto:sac-bounces@lists.osgeo.org] On Behalf Of Bob
> > > Basques
> > > Sent: Wednesday, August 2, 2023 1:56 PM
> > > To: System Administration Committee Discussion/OSGeo
> > into
> > > That will work fine.
> > > I'll let you know when I start working on it. The list is here that I'll be
> > > uploading. The backend server is down currently, so the links don't
> > work.
> > > But this is representative of what I have.
> > > https://www.osgeo.org/local-chapters/twin-cities-mn-usa-chapter/ (I
> > > have one or two that I still need to edit as well.
> > > I'll likely just repoint these links once things are uploaded.
> > > bobb
> > > FY5HWX3(new)
> > Obe
> > > > > > Sent: Wednesday, August 2, 2023 12:41 PM
> > > > > > videos into video.osgeo.org and FOSS4G youtube channel
> > organization.
> > > > > > You have to click the "Show more" to see the full description
> > > > > > and then it's the 3rd paragraph.
> > > > > > > Bob Basques
> > > > > > > Sent: Wednesday, August 2, 2023 12:21 PM
> > > > > > > videos
> > > > > > into
> > > > > > > This would be a preferred option I think, but your suggested
> > > > > > > link doesn't present anything with "geomatico" I did a search
> > > > > > > on the page with nothing coming back, is it in some other link
> > > > > > > that I'm
> > > missing?
> > > > > > > bobb
> > > > > > > FY5HWX3(new)
> > > > > > > > > > Regina
> > > > > > Obe
> > > > > > > > > > Sent: Wednesday, August 2, 2023 11:12 AM
> > > > > > > > > > 2022 videos into video.osgeo.org and FOSS4G youtube
> > > > > > > > > > channel
> > > > > > > > > > our
> > > > > > organization.
> > > > > > > > > > There is another way. Even though the description
> > > > > > > > > > section only allows plain text, I just noticed it looks
> > > > > > > > > > like It automatically hyperlinks
> > > > > > > web links.
> > > > > > > > > > Look at this one for example:
> > > > > > > > > > https://video.osgeo.org/w/gnZ9JtuoiVCwTi3EVMLRaL
> > > > > > > > > > The 1km.geomatico.es/ is plain text, but appears as a
> > > > > > > > > > clickable link in preview mode
> > > > > > > > > > That might be a cleaner way, since the description will
> > > > > > > > > > show below instead of embedded in the video like the
> > > > > > > > > > annotations
> > > > > > would.
> > > > > > > > > > > From: Regina Obe [mailto:lr@pcorp.us]
> > > > > > > > > > > Sent: Wednesday, August 2, 2023 11:32 AM
> > Discussion/OSGeo'
> > > > > > > > > > > Subject: RE: [SAC] [OSGeo] #2959: Help getting FOSS4G
> > > > > > > > > > > 2022 videos
> > > > > > > > > > into
> > > > > > > > > > > Doesn't look like you can upload none video/audio
> > content.
> > > > > > > > > > > However there is an annotations feature you can put in
> > > > > > > > > > > each video -
> > > > > > > > > > > https://framagit.org/framasoft/peertube/official-plugi
> > > > > > > > > > > ns
> > > > > > > > > > > /blob/master/peertube-plugin-video-
> > annotation/README.m
> > > > > > > > > > > d
> > > > > > > > > > > Which allows for html, so you can hyperlink those docs
> > > > > > > > > > > there
> > > > > > > > > > > For general docs, we have https://nextcloud.osgeo.org
> > > > > > > > > > > where you can put shared documents and mark them as
> > > > > > > > > > > public or only shared with a subset of users.
> > > > > > > > > > > Nextcloud you can get into with your OSGeo account
> > > > > > > > > > as well.
> > > > > > > > > > > > Behalf Of Bob Basques
> > > > > > > > > > > > Sent: Wednesday, August 2, 2023 10:35 AM
> > Discussion/OSGeo
> > > > > > > > > > > > FOSS4G
> > > > > > > > > > > > channel
> > > > > > > > > > > > Thanks for the reply,
> > > > > > > > > > > > I'll not be able to get to it right away, but I'll
> > > > > > > > > > > > let you know when I'm ready to move them. I was
> > > > > > > > > > > > going to ask if a separate channel could be set up
> > > > > > > > > > > > or not, so that is good to
> > > > > > know.
> > > > > > > > > > > > FYI, in a few instances I have corresponding PPTs
> > > > > > > > > > > > and related files for some of the presentations, any
> > > > > > > > > > > > ideas on how to keep these together in a posted
> > form?
> > > > > > > > > > > > Thanks
> > > > > > > > > > > > Bobb
> > > > > > > > > > > > > > > Sent: Wednesday, August 2, 2023 9:31 AM
> > > > > > Discussion/OSGeo'
> > > > > > > > > > > > > > > FOSS4G
> > > > > > > > > > > > > > > youtube channel
> > > > > > > > > > > > > > > outside our
> > > > > > > > > > organization.
> > > > > > > > > > > > > > > Yes. You can put on https://video.osgeo.org .
> > > > > > > > > > > > > > > You should be able to log in with your osgeo
> > > > > > > > > > > > > > > ldap account. I think I have a default quota
> > > > > > > > > > > > > > > set to 10 GB per day / max 100 GB per user,
> > > > > > > > > > > > > > > but I can up that if you need
> > > > > > > more space than that.
> > > > > > > > > > > > > > > You should also be able to create a channel for it.
> > > > > > > > > > > > > > > Let me know if you need any help with that.
> > > > > > > > > > > > > > > Thanks,
> > > > > > > > > > > > > > > Regina
> > > > > > > > > > > > > > > > From: Sac
> > > > > > > > > > > > > > > > On Behalf Of Bob Basques
> > > > > > > > > > > > > > > > Sent: Wednesday, August 2, 2023 10:00 AM
> > > > > > > > > > > > > > > > To: sac@lists.osgeo.org
> > > > > > > > > > > > > > > > getting FOSS4G
> > > > > > > > > > > > > > > > 2022 videos
> > > > > > > > > > > > > > > into
> > > > > > > > > > > > > > > > All,
> > > > > > > > > > > > > > > > Is there a location for Chapter meeting
> > > > > > > > > > > > > > > > video to be store/posted
> > > > > > > > > > > > > > > online? I
> > > > > > > > > > > > > > > > have a couple of years worth for our local
> > Chapter.
> > > > > > > > > > > > > > > > Bobb
> > > > > > > > > > > > > > > > FY5HWX3(new)
> > > > > > > > > > > > > > > > > > > From: Sac
> > > > > > > > > > > > > > > > > > > Behalf Of OSGeo
> > > > > > > > > > > > > > > > > > > Sent: Tuesday, August 1, 2023 8:46 PM
> > > > > > > > > > > > > > > > > > > Cc: sac@lists.osgeo.org
> > > > > > > > > > > > > > > > > > > Subject: [SAC] [OSGeo] #2959: Help
> > > > > > > > > > channel
> > > > > > > > > > > > > > > organization.
> > > > > > > > > > > > > > > > > > > youtube channel
> > > > > > > > > > > > > > > > > > > Reporter: robe | Owner: sac@…
> > > > > > > > > > > > > > > > > > > Type: task | Status: new
> > > > > > > > > > > > > > > > > > > Priority: normal | Milestone:
> > Sysadmin
> > > > > > Contract
> > > > > > > > > > 2023-I
> > > > > > > > > > > > > > > > > > > Component: Systems Admin |
> > Keywords:
> > > > > > > > > > > > > > > > > > > There is currently some difficulty
> > > > > > > > > > > > > > > > > > > with getting FOSS4G
> > > > > > > > > > > > > > > > > > > 2022 videos into Youtube because of
> > > > > > > > > > > > > > > > > > > rate limits
> > > > > > etc.
> > > > > > > > > > > > > > > > > > > So plan is to load them into our
> > > > > > > > > > > > > > > > > > > Peertube instance video.osgeo.org and
> > > > > > > > > > > > > > > > > > > then push them also to Youtube using
> > > > > > > > > > > > > > > > > > > the
> > > > > > > > > > > > > > > > Youtube API.
> > > > > > > > > > > > > > > > > > > I'm still reviewing how we can achieve
> > this.
> > > > > > > > > > > > > > > > > > > As far as loading into
> > > > > > > > > > > > > > > > > > > video.osgeo.org, I think I just need
> > > > > > > > > > > > > > > > > > > to allocate a staging folder to scp
> > > > > > these up.
> > > > > > > > > > > > > > > > > > > And then we can use the Peertube
> > > > > > > > > > > > > > > > > > > upload api reading from a CSV file to
> > > > > > > > > > > > > > > > > > > load in the videos and associated meta
> > > > > > > > > > > > > > > > > > > data, like discussed here
> > > > > > > > > > > > > > > > > > > https://beeldengeluid.github.io/extend
> > > > > > > > > > > > > > > > > > > in
> > > > > > > > > > > > > > > > > > > g-
> > > > > > > > > > > > > > > > > > > peertube/migration/2021/07/06
> > > > > > > > > > > > > > > > > > > /importing-videos-with-the-api.html
> > > > > > > > > > > > > > > > > > > using the Peertube upload cli
> > > > > > > > > > > > > > > > > > > https://docs.joinpeertube.org/maintain
> > > > > > > > > > > > > > > > > > > /t ools #peertube-upload-js
> > > > > > > > > > > > > > > > > > > I think things are a bit easier since
> > > > > > > > > > > > > > > > > > > that article was written 2 years
> > > > > > > > > > > > > > > ago.
> > > > > > > > > > > > > > > > > > > The Youtube side worst case, I think
> > > > > > > > > > > > > > > > > > > we just read from the staging folder
> > > > > > > > > > > > > > > > > > > and process using the existing Youtube
> > > > > > > > > > > > > > > > > > > script we have perhaps just having it
> > > > > > > > > > > > > > > > > > > load 5 a day or
> > > > > > > > > > > so.
> > > > > > > > > > > > > > > > > > > I haven't looked that deeply into
> > > > > > > > > > > > > > > > > > > Youtube, but I couldn't find a way to
> > > > > > > > > > > > > > > > > > > just import a video url stream, like
> > > > > > > > > > > > > > > > > > > Peertube offers for (Youtube, Vimeo,
> > > > > > > > > > > > > > > > > > > and
> > > > > > > > > > Dailymotion).
> > > > > > > > > > > > > > > > > > > That would be the ideal
> > > > > > > > > > > > > > > solution.
> > > > > > > > > > > > > > > > > > > Ticket URL:
> > > > > > > > > > > > > > > > > > > <https://trac.osgeo.org/osgeo/ticket/2
> > > > > > > > > > > > > > > > > > > 95
> > > > > > > > > > > > > > > > > > > 9> OSGeo <https://osgeo.org/> OSGeo
> > > > > > > > > > > > > > > > > > > committee
> > > > > > and
> > > > > > > > > > general
> > > > > > > > > > > > > > > > > > > foundation issue tracker.
> > > > > > _______________________________________________
> > > > > > > > > > > > > > > > Sac mailing list Sac@lists.osgeo.org
> > > > > > > > > > > > > > > > https://lists.osgeo.org/mailman/listinfo/sac
> > > > > > > > > > > > Sac mailing list
> > > > > > > > > > > > Sac@lists.osgeo.org
> > > > > > > > > > Sac mailing list
> > > > > > > > > > Sac@lists.osgeo.org
> > > > > > > Sac mailing list
> > > > > > > Sac@lists.osgeo.org
> > > > > > Sac mailing list
> > > > > > Sac@lists.osgeo.org
> > > Sac mailing list
> > > Sac@lists.osgeo.org
> > Sac mailing list
> > Sac@lists.osgeo.org
