#2979: Upgrade weblate to 5.0
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Keywords:
We are currently running 4.16.4 which is two minors behind.
At a glance there doesn't seem to be any breaking changes we should be
concerned about.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2979>
OSGeo <Gter - OSGeo;
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I tried upgrading to 5.0, but was taking a while, so I reverted the
container to the snapshot I took before i started.
So I'm doing 4.18.2 but this seems to be taking while too. I guess I was
just too impatient, seem to be quite a few structural changes.
If this succeeds maybe I'll try 5.0 tomorrow.
One feature that looks useful for 5.0 is
1. category can now organize components within a project.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2979#comment:1>
OSGeo <https://osgeo.org/>
Keywords: |
Comment (by robe):
Okay 4.18.2 is taking a while too, but I think it's really just major db
structural changes.
Showing this at moment
docker-compose logs -f
weblate_1 | Applying memory.0016_remove_blank... OK
weblate_1 | Applying metrics.0014_metricfuture... OK
weblate_1 | Applying metrics.0015_migrate_metrics...Converting metric
entries, this might take long
So I guess I just got to be patient with the "this might take long"
Hopefully 5.0 upgrade should be faster, I think most of the structural
change is in 4.18
Lots of stuff happened in 4.18
https://github.com/WeblateOrg/weblate/releases/tag/weblate-4.18
Improved API error messages on permission denied.
Reduced false positives of the XML checks.
Translated check accuracy has been improved.
Extended support for Fluent file format.
Avoiding signing-out user in some rate-limits.
Added support for storing glossary explanation in TBX format.
Added support for ordering strings by last update.
Extended search capabilities for finding users.
Support for automatic update of screenshots from a repository.
Improved translation memory performance.
Project stats exports to JSON/CSV now include more details; it now
matches content available in the API.
Added check for reused translation.
Highlight suggested change in automatic suggestions.
Added dark theme; browser-following and manual setting are
available.
The Docker container can now be used with read-only root filesystem.
Added username autocompletion when adding users to a project.
Added site-wide search for projects, components, languages and
users.
New add-on Fill read-only strings with source.
and 4.17, seems to be the rewritten metrics storage that is taking a while
to migrate
Allow to filter on language in reports.
Dropped deprecated command cleanup_celery.
Fixed private project visibility for some teams.
Automatic translation now honors target state when translating from
other components.
Improved performance of public user profiles.
Improved Sentry performance integration.
Added support for Ed25519 SSH key.
Rewritten metrics storage.
Added support for searching strings by position.
Documentation improvements.
Unchanged translation check can honor untranslatable terms from
glossary.
Added automatic fixup for Devanagari danda.
Allow downloading project translation memory per language.
Added new alert on unused components.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2979#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
oops I thought I was upgrading to 4.18, but I had forgotten to edit the
docker-compose file to 4.18, so it upgraded to 5.0, which I guess is okay.
Going to close this out.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2979#comment:3>
