#2980: Change default committer name and email on weblate
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Neteler,
Hmm I guess this isn't detailed here -
https://wiki.osgeo.org/wiki/SAC:Weblate
I apologize. I'll try to flesh that out a bit.
What I am talking about here, is how the commits credits shows on github.
It doesn't change the process.
Below the commits would show "weblate" even though it was "osgeoweblate"
because it has noreply@weblate.com as the email address. and if people
would click on the link, it would take them to github/osgeoweblate
instead of github.com/osgeoweblate as you can see in workshop contributors
- https://github.com/postgis/postgis-workshops/graphs/contributors and the
combined would do the same - https://github.com/postgis/postgis-
workshops/commit/25f3aab715ff75aba7b4d353de418205f9ad837f (authored by
real author, committed by weblate).
So this change is mostly cosmetic and to get rid of confusion, and doesn't
affect the flow (or at least shouldn't).
Now to you question about staleness
It looks like grass is setup right - using Github Pull Request mode, but I
am seeing this notice
"The repository is outdated. You might not get expected results until you
update it."
So yours seems to be a separate issue which I'll ticket as a separate
But so I remember to update wiki
So here is the process.
There are two approaches you can go with whichever makes you feel most
comfortable
1. You can specify in weblate, you want just git. If you go with that you
have to
a) Give osgeoweblate commit access to your repo
(with option of allowing commit or waiting for someone to manually push) -
this is the option that postgis core project uses
https://git.osgeo.org/gitea/postgis/postgis/commit/b74322912e5321e6df5bcbe0457cb40e8117bbdd
(we don't bother with pull requests, just let it flow thru and if it
breaks something we handle it after it has been dropped)
or
b) Manually download and push the commits yourself
Option 2
2. You specify Github Pull mode (on your base component, the component
that all your other components were copied from):
(this is what https://github.com/postgis/postgis-workshops uses and
pgrouting and osgeolive I think)
https://weblate.osgeo.org/settings/grass-gis/grasslibs/#vcs and grass is
doing
(I think you should be able to see that page with your ldap account), note
there we have:
Version control system: Github pull request
When you choose Github pull request, it uses the github account
osgeoweblate, I had set up for this purpose. This account acts like a
person, pulling in weblates changes and then creating a pull request
against your repo.
I should add regardless the option you choose, there is a "Component
discovery" plugin you should install on the first component you set up.
This allows weblate to auto-generate new components based on the pattern
of your first component and I think it has a checkbox to also remove no
longer present components.
That last bit might be what grass is missing. Anyway let me put in a
separate ticket for grass issue.
PostGIS workshop which uses the pull request model:
Here is how it works
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2980#comment:2>
OSGeo <https://osgeo.org/>
