#2981: Weblate grass project not updating
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-II
Component: Systems Admin | Keywords:
It seems even though Grass project is set to use Github Pull Request, it
is not doing it.
On closer inspection, looking at https://weblate.osgeo.org/projects/grass-
gis/grasslibs/#repository
I see a notice:
On branch main
Your branch and 'origin/main' have diverged,
and have 11 and 4 different commits each, respectively.
(use "git pull" to merge the remote branch into yours)
nothing to commit, working tree clean
and
0 pending changes
This will commit any pending changes present in Weblate and not in the
repository.
11 outgoing commits
This will push changes and create a GitHub pull request.
4 missing commits
This will update the Weblate repository with the upstream changes.
So the issue is that the local weblate repo and grass repo have diverged
for some reason.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981>
OSGeo <Gter - OSGeo;
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Okay I clicked the update button in weblate here -
Now I see this pull request. It might have gotten out of sync because the
pull request was done a while ago and hadn't been accepted yet.
https://github.com/OSGeo/grass/pull/3065
@neteler, if this looks okay to you, can you go ahead and accept, and that
might just fix it moving forward.
I think the way weblate works, it can have only one outstanding pull
request and just keeps adding to that one, and may freeze submission if it
feels it's original is getting too out of sync.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:1>
OSGeo <https://osgeo.org/>
Keywords: |
Comment (by robe):
I am bummed the author is still showing weblate. Might be I have a
mistake or because it had those already committed to it's local git repo,
it couldn't change the committer. I'm hoping the latter.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:2>
Keywords: |
Comment (by robe):
the osgeoweblate fork looks updated now -
https://github.com/osgeoweblate/grass/tree/weblate-grass-gis-grasslibs
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:3>
Keywords: |
Comment (by neteler):
Replying to [comment:1 robe]:
the pull request was done a while ago and hadn't been accepted yet.
that might just fix it moving forward.
Yeah - seems we didn't know that keeping it open for collecting more
translations generates troubles at this end.
I see - good to know.
I have triggered the CI in the PR 3065 so that it passes for merging. I'll
keep an eye on it.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:4>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
* milestone: Sysadmin Contract 2023-II => Sysadmin Contract 2023-I
Comment:
okay will close this out. Feel free to open if you find it's still an
issue.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:5>
Type: task | Status: reopened
Keywords: |
Changes (by neteler):
* status: closed => reopened
* resolution: fixed =>
Comment:
There seems to be a new issue:
Now, updating its repo fails with
Rebasing (1/11)
error: could not apply 96fa6b652... Translated using Weblate (Russian)
Resolve all conflicts manually, mark them as resolved with
"git add/rm <conflicted_files>", then run "git rebase --continue".
You can instead skip this commit: run "git rebase --skip".
To abort and get back to the state before "git rebase", run "git rebase
--abort".
Could not apply 96fa6b652... Translated using Weblate (Russian)
Auto-merging locale/po/grasslibs_ru.po
CONFLICT (content): Merge conflict in locale/po/grasslibs_ru.po
(1)
Reported in:
https://github.com/OSGeo/grass/pull/3065#issuecomment-1715057905
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:6>
Keywords: |
Comment (by robe):
Okay will look at this later today.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:7>
Keywords: |
Comment (by robe):
Okay setting up the hook as discussed in pull request and you did is the
first step.
For the remaining issue I went here:
https://weblate.osgeo.org/projects/grass-gis/#repository
and chose "Update with merge without fast-forward". Was the only one I
could choose short of getting into the weblate git repo and trying to
guess how to merge.
So that created another pull request here -
https://github.com/OSGeo/grass/pull/3151
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:8>
Keywords: |
Comment (by hcho):
@robe Thanks! I think that worked. You said "pushes happen on every commit
to your repo" in
https://github.com/OSGeo/grass/pull/3065#issuecomment-1716446226. Does it
mean pushes from GitHub to Weblate, not the other way around?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:9>
Keywords: |
Comment (by robe):
Replying to [comment:9 hcho]:
commit to your repo" in
Yes when you make a commit on github, it calls the webhook on weblate
which triggers a refresh of weblate's git copy of your repo.
As far as pushing back, I think there is a setting in weblate for that and
defaults to something like 24 hrs, though you can tweak that setting. I
think that just prevents pushes happening constantly while someone is
editing on weblate. It's probably less of a concern when in pull request
mode.
I think something might still be wrong, cause I'm seeing missing commit in
weblate again, but not sure if that's just cause you haven't merged.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:10>
Keywords: |
* Attachment "weblate_syncing_github.png" added.
Weblate sync with GitHub
Keywords: |
Replying to [comment:8 robe]:
first step.
There is still an issue (maybe the third file?). What I see is this:
[[Image(weblate_syncing_github.png)]]
@robe I am not sure where to find the button or menu entry you mention...
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:11>
Keywords: |
Comment (by robe):
Click on the Manage -> Repository Maintenance
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:12>
Keywords: |
Comment (by robe):
I tried rebase push again and it generated another pull request
https://github.com/OSGeo/grass/pull/3154/
Not quite sure what's going on here. The changes do look different but
just puzzled why so many changes are stuck
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:13>
Keywords: |
I now managed to find the "Update" stuff in Weblate.
This just generated a new PR but it is with 15 commits but empty:
https://github.com/OSGeo/grass/pull/3156/files
Confusing...
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:14>
Keywords: |
Comment (by robe):
When I look at the individual files, it shows a diffs though
https://github.com/OSGeo/grass/pull/3156/commits/96fa6b65269767cd9110460f754bc03c68ffdfc0
. So not sure why it's showing 0 for files.
I propose that after this pull request, if this cycle continues, we hit it
with a hammer using
one of the red buttons
Reset all changes in the Weblate repository
Resetting removes all changes in Weblate so that the repository matches
upstream. Use when you want to discard changes in Weblate and bring it in
sync with upstream repository.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:15>
Keywords: |
Comment (by cvvergara):
Again, all the components of GRASS GIS are blocked.
This repository is not up to date:
7 commits behind of
The main problem is conflicts within the Russian translation.
Will follow this instructions:
Typical workflow for fixing merge conflicts
Commit all pending changes in Weblate and lock the translation component.
(already locked)
wlc commit; wlc lock
Add Weblate exported repository as a remote.
git remote add weblate https://weblate.osgeo.org/git/grass-
gis/grasslibs/
git remote update weblate
Merge Weblate changes and resolve any conflicts.
git merge weblate/
Rebase Weblate changes on top of upstream and resolve any conflicts.
git rebase origin/
Push changes into upstream repository.
git push origin
Weblate should now be able to see updated repository and you can unlock
it. (can be unlocked in the weblate site)
wlc pull ; wlc unlock
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:16>
Keywords: |
mayority of conflicts happen on the header of the po file
<<<<<<< HEAD
"PO-Revision-Date: 2023-08-23 07:08+0000\n"
"PO-Revision-Date: 2023-06-28 19:08+0000\n"
>>>>>>> eeff31d386 (Translated using Weblate (German))
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:17>
Keywords: |
While doing the rebase:
dropping 988f5950a66be361cf941d0e1e51a84125542f4a Translated using Weblate
(Russian) -- patch contents already upstream
dropping 73a260d053c068002acabaee212dcb71f30bccc8 Translated using Weblate
(German) -- patch contents already upstream
dropping c679724f004d10b86ab3883f492e633b0adfb884 Translated using Weblate
dropping 9c70f73ac03fb1957b56d96255de6ee851f69be2 Translated using Weblate
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2981#comment:18>
