#2994: wordpress-dev updates from wordpress
Reporter: cvvergara | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: Systems Admin | Keywords:
Setup and scripts to get wordpress backup into wordpress-dev
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2994>
OSGeo <Gter - OSGeo;
Component: Systems Admin | Resolution:
Keywords: wordpress |
Changes (by cvvergara):
* keywords: => wordpress
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2994#comment:1>
OSGeo <https://osgeo.org/>
Comment (by robe):
Note as part of this - created a local lxchopper1 account on osgeo9 so we
can use that as hop between wordpress-dev and wordpress prod
https://git.osgeo.org/gitea/sac/ansible-
deployment/commit/f03fd748a2d14eb876b43c30204dca8443b80de9 for scping
database and website folder backups.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2994#comment:2>
Comment (by strk):
Isn't wordpress-dev just an exact copy of wordpress taken via lxc ? I'm
confused as to why a connection between prod and dev (staging?) is needed
at the ssh level. Also shouldn't any OSGeo user in the "shell" group be
allowed to ssh into both, thus allowing use of ssh-agent to travel between
the two ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2994#comment:3>
Comment (by robe):
Because sometimes we are doing stuff and we just want to pull a new backup
without having to go thru the whole ansible process of recreating the
container. For most containers we never need to do this e.g. I never
bother with tracsvn-dev.
Yes any user in shell group is allowed. But I don't want my key installed
on dev, and just easier if a local user on wordpress-dev can hook into
local user on wordpress-prod.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2994#comment:4>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
@cvvergara I created script
/var/www/backups/scripts/restore_osgeo_from_prod.sh in osgeo4-wordpress-
dev
It downloads the latest site and database backups from prod, restores the
db and the files, and updates the config.php so it points to
dev.www.osgeo.org. I'm doing a trial run of it again.
I'll leave it up to you to decide which git repo the scripts should be
stored.
Also the old osgeo.org, I backed up in /var/www/osgeo.org.231005
I'm also debating if we really need a staging repo at all since the only
code difference that would be different between prod and dev.www.osgeo.org
would be in the config.php file which isn't even stored in the git repo.
but anyway something is screwed up with staging and can't figure out what
cause when I check out it does like you said remove a bunch of stuff and
complains it's diverged from the gitea repo.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2994#comment:5>
Comment (by cvvergara):
About:
"but anyway something is screwed up with staging and can't figure out what
complains it's diverged from the gitea repo."
I just created `develop` branch that is an exact copy of master and is the
default branch. I will remove staging later on as it has some experiments
I was doing eons ago, that are interesting.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2994#comment:6>
