#3004: free.fr about to block mails from osgeo due to excess errors
Reporter: strk | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-II
Component: Mails & Mailing Lists | Keywords:
Postmaster.free.fr said:
IP 140.211.15.3 is blacklisted for 79668s (too many errors (unexisting
recipients, broken connections), testing)
In the email, the error code is 421 :
421 Too many errors from your IP
Reason
Your IP address is not blocked, but we do not accept anymore emails from
you
temporarily due to too much errors generated by your server. If your
server
continue to generate a big amount of errors, you will be blacklisted for a
while and get the "550 Too many errors from your IP" error.
Solution
If you host your own SMTP server : while waiting this delay, we
recommend
you to verify your configuration (maybe you are an open relay ?). If you
are
using the “Sender Verify” method which make a connection to our servers to
verify the validity of an email, we recommend you to disable it. Your
server
may also send automatic notices (undeliverable mails, autoreplies; etc.)
when
receiving spams. In this case, you should try to refuse a mail delivery
the
soonest possible (while receiving it) to avoid to have to deliver a
delivery
status notification and/or not to send an automatic reply on mails
detected as
spams.
If you are using a SMTP relay: please contact your service provider\.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3004>
OSGeo <Gter - OSGeo;
Component: Mails & Mailing | Resolution:
Lists |
Keywords: |
Comment (by lnicola):
Another example, from SourceForge: https://sourceforge.net/p/forge/site-
support/19539/
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3004#comment:1>
OSGeo <https://osgeo.org/>
Component: SysAdmin/Postfix | Resolution:
Keywords: |
Changes (by strk):
* component: Mails & Mailing Lists => SysAdmin/Postfix
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3004#comment:2>
Keywords: |
Changes (by cvvergara):
* milestone: Sysadmin Contract 2023-II =>
Comment:
I am unsettling the milestone as I could not find a solution.
140dot211dot15dot3 is still blacklisted by free.fr
In the link provided, there was never a solution, but after 11 months of
waiting if got unlisted and then listed back again.
Ticket URL: <#3004 (free.fr about to block mails from osgeo due to excess errors) – OSGeo;
Priority: normal | Milestone: Unplanned
Keywords: |
* milestone: => Unplanned
Priority: normal | Milestone: Sysadmin Contract 2024-III
Keywords: |
Changes (by strk):
* milestone: Unplanned => Sysadmin Contract 2024-III
