#3008: Source code of spatialreference.org
Reporter: rouault | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
we are considering reviving spatialreference.org (still in exploratory
mode), and would like to have access to the source code of the side. Can
someone helps uncovering it ?
Thanks
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3008>
OSGeo <Gter - OSGeo;
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: SysAdmin | Resolution:
Keywords: |
Changes (by robe):
* milestone: Unplanned => Sysadmin Contract 2023-I
Comment:
I thought hobu said it's in svn. svn.osgeo.org is still alive so assume
it is still there. I recall Howard had mentioned to me once where the code
is, but I can't remember
You should also be able to access the server too. It's on old-projects
running on osgeo7
http://old-projects:8092/. I assume some sort of wsgi, but don't know the
server enough to know where the scripts are located
So following directions here
https://wiki.osgeo.org/wiki/SAC_Service_Status#Logging_into_LXD_Containers_and_VMs
and then
{{{ ssh rouault@osgeo7-old-projects }}}
should get you in.
The database I am assuming is the one called srorg on PostgreSQL 8.3
running postgis 1.3.3.
Let me know if you want me to setup a fresh server for your new version
and what kind instance Debian or Ubuntu are templates we currently have
available.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3008#comment:1>
OSGeo <https://osgeo.org/>
Keywords: |
Comment (by rouault):
> svn.osgeo.org is still alive so assume it is still there.
oh, I believe it must be there: https://svn.osgeo.org/metacrs/sr.org/
thanks!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3008#comment:2>
Type: task | Status: closed
Component: SysAdmin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3008#comment:3>
