#3027: nextcloud upgrade to 26.0.8
Reporter: robe | Owner: robe
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2023-I
Component: SysAdmin/Nextcloud | Keywords:
We are currently running nextcloud 25.0.12
The 25.0.13 is the EOL one. So rather than bothering with that, going to
go to 26, so we are still in supported mode.
I'm going to briefly test in dev and then make the change in prod,
hopefully later tonight.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3027>
OSGeo <Gter - OSGeo;
Component: SysAdmin/Nextcloud | Resolution:
Keywords: |
Comment (by robe):
did a trial upgrade in https://dev-nextcloud.osgeo.org which is against a
snapshot of a day ago. Seemed to be fine except took a bit longer for it
to start up so scared me a bit.
There seems to be an issue with the only office even after changing the
url to https://dev-
nextcloud.osgeo.org/apps/documentserver_community/healthcheck
going to investigate before I try upgrading the production one.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3027#comment:1>
OSGeo <https://osgeo.org/>
Keywords: |
Comment (by robe):
Okay it seemed to have just disabled it. I had to reenable and explicitly
resave the configuration. Sadly the PDF export is still broken. I'm
going to go ahead and upgrade production. Not any worse than we have now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3027#comment:2>
Type: task | Status: closed
Component: SysAdmin/Nextcloud | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Done upgrading production. took a bit to start up.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/3027#comment:3>
