#357: random server errors
Reporter: pcav | Owner: sac@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Component: SAC
Keywords: |
I get random errors:
Internal Server Error
The server encountered an internal error or misconfiguration and was
unable to complete your request.
Please contact the server administrator, root@localhost and inform them
of the time the error occurred, and anything you might have done that
may have caused the error.
More information about this error may be available in the server error
log.
Apache/2.0.52 (Red Hat) Server at trac.osgeo.org Port 443
and
Oops…
Trac detected an internal error:
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 387, in
dispatch_request
dispatcher.dispatch(req)
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 191, in
dispatch
chosen_handler = self._pre_process_request(req, chosen_handler)
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 263, in
chosen_handler = f.pre_process_request(req, chosen_handler)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py",
line 73, in pre_process_request
self.get_repository(req.authname) # triggers a sync if applicable
line 101, in get_repository
repos = self._connector.get_repository(rtype, rdir, authname)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/svn_fs.py",
line 260, in get_repository
crepos = CachedRepository(self.env.get_db_cnx(), repos, None,
self.log)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/cache.py",
line 34, in __init__
self.sync()
line 56, in sync
cursor.execute("SELECT value FROM system WHERE name='repository_dir'")
File "/usr/lib/python2.3/site-packages/trac/db/util.py", line 51, in
execute
return self.cursor.execute(sql)
File "/usr/lib/python2.3/site-packages/sqlite/main.py", line 244, in
execute
self.rs = self.con.db.execute(SQL)
OperationalError: database is locked
More generally, the server is quite slow. Also, it appears partly
misconfigured, and based on a rather old apache. And very old python.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/357>
OSGeo <http://www.osgeo.org/>
