#358: Live-demo group's bug/wish/task trac
Reporter: hamish | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: normal | Component: SAC
Keywords: LiveDVD |
over on the osgeo live-demo mailing list we've been discussing our
infrastructure needs. I had thought we were lacking a SVN home for our
config and build scripts, but apparently there is already
https://svn.osgeo.org/osgeo/livedvd, wonderful.
Before we start sending folks to this osgeo trac instance to file bugs and
wishes, I thought I'd ask
that a LiveDVD component be added to the
ticket properties component list, or if that is deemed to be too noisy to
investigate our subproject getting its own trac instance + svn repo. My
expectation is that the ticket volume will be very small, and my
understanding is that SVN allows per-directory access control, so my guess
would be that we could co-exist in this trac instance with minimal impact
or need for support. But maybe it is trivial to set another one up. ??
comments?
thanks,
Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/358>
OSGeo <http://www.osgeo.org/>
Resolution: | Keywords: LiveDVD
Comment (by hamish):
ps- see http://wiki.osgeo.org/wiki/Live_GIS_Disc
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/358#comment:1>
Type: task | Status: closed
Resolution: fixed | Keywords: LiveDVD
Changes (by warmerdam):
* status: new => closed
* resolution: => fixed
Comment:
I have created a LiveDVD component with hamish as the default assignee.
Setting up new trac instances, ensuring the are properly backed up, and so
forth is not a trivial effort.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/358#comment:2>
Comment (by warmerdam):
I have added hamish to the TRAC_ADMIN list for this trac instance in case
adjustments are needed.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/358#comment:3>
cheers.
I have changed the default assignee to the group's mailing list address.
TODO: find out if trac's outgoing notification has to be manually
subscribed to the live-demo listserv in order to get around the have-to-
be-subscribed-to-post check or if there is some soft of bypass already in
place.
Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/358#comment:4>
Comment (by neteler):
I have added instructions here:
http://wiki.osgeo.org/wiki/Trac_Instances#Trac_notification_forward_to_project_mailing_list
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/358#comment:5>
thanks to all for the quick help.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/358#comment:6>
