#365: SectionEditPlugin for trac
Reporter: martinl | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: normal | Component: SAC
Keywords: trac |
would be possible to install Trac EditSectionPlugin?
http://trac-hacks.org/wiki/SectionEditPlugin
Would be __very__ useful?
Martin
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/365>
OSGeo <http://www.osgeo.org/>
Resolution: | Keywords: trac
Comment (by martinl):
So am I really alone who thinks that it's very useful extension of trac
wiki? ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Martin
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/365#comment:1>
Probably the problem is that EditSectionPlugin requires trac version 0.11
http://trac-hacks.org/svn/sectioneditplugin/
and osgeo uses 0.10.3.1. Any change to switch to the newer version?
Martin
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/365#comment:2>
Comment (by hobu):
We need to migrate to using sqlite3 first, make sure we've improved our
stability with that. We have 30 trac instances to migrate.
We also have customizations because of our LDAP setup that must be brought
forward if we are to migrate to 0.11.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/365#comment:3>
Replying to [comment:3 hobu]:
brought forward if we are to migrate to 0.11.
OK, and is this migration planned in the short-term period (weeks)? If so
I am prepared to help with that (limited experience with trac)...
Martin
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/365#comment:4>
Comment (by martin):
I'm listening. Do you have a pointer for me ?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/365#comment:5>
Reporter: martinl | Owner: sac@…
Priority: normal | Component: Systems Admin
Keywords: trac |
Comment(by crschmidt):
We are on 0.11 now.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/365#comment:6>
Keywords: trac |
Comment(by neteler):
Could an enabled SAC member please install it?
Install
easy_install http://trac-hacks.org/svn/sectioneditplugin/0.11
Don't forget to put this into your trac.ini:
[components]
tracsectionedit.* = enabled
or to enable it through the /admin/general/plugin panel.
* Note: web server or Trac reboot not required.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/365#comment:7>
Type: task | Status: closed
Resolution: fixed | Keywords: trac
Changes (by crschmidt):
* status: new => closed
* resolution: => fixed
Comment:
neteler: I have no idea what project you want it for, however
SectionEditPlugin is installed and activated for Grass. Was there another
project I should enable it for?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/365#comment:8>
Changes (by neteler):
* cc: neteler (added)
Comment:
GRASS is just fine. Thanks.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/365#comment:9>
