#387: GGL Trac: email ggl list on change
Reporter: mloskot | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: normal | Component: SAC
Keywords: ggl,list,notification |
GGL team has got infected by PostGIS team with [ticket:380 spam adoration
virus] and we would like to kindly ask for setting up [/ggl/ GGL Trac] to
sent email to [http://lists.osgeo.org/mailman/listinfo/ggl ggl] on every
ticket change.
Assuming from the PostGIS ticket comments, From: field is set with
trac@osgeo.org so Barend will need to ensure this e-mail is allowed to
post into the list.
Thanks!
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/387>
OSGeo <http://www.osgeo.org/>
Resolution: | Keywords: ggl,list,notification
Comment (by hobu):
Notification configuration complete. Please test to confirm.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/387#comment:1>
Comment (by mloskot):
Hobu,
Thanks. Could you please confirm what's the sender address (from)?
In PostGIS' ticket, Paul identified it as trac@osgeo.org, but OSGeo Trac
sends as trac_osgeo@osgeo.org. For instance, GEOS Trac notifications are
sent as geos-trac@osgeo.org.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/387#comment:2>
Type: task | Status: closed
Resolution: fixed | Keywords: ggl,list,notification
Changes (by mloskot):
* status: new => closed
* resolution: => fixed
Comment:
Hobu,
It looks everything works well. We've started to get Trac posting to the
list.
Here is example what we get:
-------- Original Message --------
Subject: Re: [GGL] #15: Rename upper-case metafunction value in point_type
Date: Sun, 21 Jun 2009 19:52:10 -0000
Reply-To: trac@osgeo.org
CC: ggl@lists.osgeo.org
References: <051.a5867095403cb922db54059ba255ebc7@osgeo.org>
Reporter: mloskot | Owner: barendgehrels
Type: task | Status: assigned
Priority: major | Milestone: <unspecified>
Component: ggl/core | Version: svn-trunk
Resolution: | Keywords: naming,point_type,metafunction
OK. I see you've assigned this to yourself, so I'll leave it to you.
Ticket URL: <http://trac.osgeo.org/ggl/ticket/15#comment:4>
GGL <http://geometrylibrary.geodan.nl> Generic Geometry Library
'''Thank you very much'''
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/387#comment:3>
