#388: Postgis Trac can you run this update now
Reporter: robe | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: normal | Component: SAC
Keywords: |
Can you run the below update statement of the PostGIS SQLite trac db.
UPDATE ticket SET status = 'new', resolution=null where id = 145;
this ticket we brought over from google bug tracker, I must have
accidentally stamped an invalid status on it so now I can't close it
because its in limbo. I suspect the above update should fix my problem.
Regina
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/388>
OSGeo <http://www.osgeo.org/>
