#397: xblade14-2 Upgrade Sphinx to 0.6.2
Reporter: jive | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: normal | Component: SAC
Keywords: |
Morning - we have run into a couple of issues with "make html" from
/osgeo/geotools/geotools-web/sphinx
The site builds fine from a range of personal machines; but fails from
xblade14-2:
File "/usr/lib/python2.4/site-packages/Jinja-1.2-py2.4-linux-
i686.egg/jinja/parser.py", line 1148, in _sanitize_tree
self.filename)
TemplateSyntaxError: misplaced block 'rootrellink', blocks in child
templates must be either top level or located in a block tag.
(page.html, line 24)
The full traceback has been saved in /tmp/sphinx-err-h8Elch.log, if
you want to report the issue to the author.
The main difference we can see is the version of Sphinx install: 0.6.0 vs
0.6.2. Justin has installed 0.6.2 in his home directory and confirms that
the upgrade fixes the build issue (see discussion here
http://n2.nabble.com/Unable-to-update-test.geotools.org-
td3313788.html#a3313788).
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/397>
OSGeo <http://www.osgeo.org/>
