#508: PostGIS trac is corrupted
Reporter: robe | Owner: sac@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Component: SAC
Keywords: |
Getting a primary key violation. It might have been the last merge I did
that did it.
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 387, in
dispatch_request
dispatcher.dispatch(req)
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 191, in
dispatch
chosen_handler = self._pre_process_request(req, chosen_handler)
File "/usr/lib/python2.3/site-packages/trac/web/main.py", line 263, in
chosen_handler = f.pre_process_request(req, chosen_handler)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/api.py", line
73, in pre_process_request
self.get_repository(req.authname) # triggers a sync if applicable
101, in get_repository
repos = self._connector.get_repository(rtype, rdir, authname)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/svn_fs.py",
line 260, in get_repository
crepos = CachedRepository(self.env.get_db_cnx(), repos, None,
self.log)
File "/usr/lib/python2.3/site-packages/trac/versioncontrol/cache.py",
line 34, in __init__
self.sync()
line 104, in sync
(str(current_rev), path, kind, action,
File "/usr/lib/python2.3/site-packages/trac/db/util.py", line 50, in
execute
return self.cursor.execute(sql_escape_percent(sql), args)
execute
IntegrityError: duplicate key violates unique constraint "node_change_pk"
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/508>
OSGeo <http://www.osgeo.org/>
