#574: OSGeo SVN server(s) unresponsive during certain hours of the day
Reporter: jng | Owner: sac@lists.osgeo.org
Type: defect | Status: new
Priority: normal | Component: Systems Admin
Resolution: | Keywords:
Comment (by hamish):
crschmidt wrote:
> > 2. We don't know why.
Martin S wrote:
> BTW, I disagree on 2.).
so....... what is it?
do we have proof or just long term suspicion?
LDAP on osgeo1 going haywire?
after 24 hours of load monitoring on xblade13 and 14 (see plot image
attached to this ticket):
xblade13 (1.5GHz Athlon, 1GB RAM)
- pretty quiet execpt for 7:49 thru 9:54 UTC when rsync is running full
bore
(timing wrt the 8 o'clock "dead hour" is rather suspicious...)
xblade14 (1.5GHz Athlon, 1GB RAM)
- periodic large httpd bursts (flushing queue after a stall?),
- a number of mapserver jobs chewing up cpu,
- buildbots running (pid 3798 gdal build stuck & consuming a lot of RAM?)
- 24 hr avg load ~ 70% CPU utilization; min. 250mb RAM free
full logs available on request or just collect some yourself -- improved
load monitoring script:
#!/bin/sh
# script to log cpu use etc.
# log every 5 minutes
interval=300
outfile=~/"cpu_use.`hostname -s`.log"
#echo "Will consume about $((50 * 3600/$interval * 24 / 1024)) kb/day"
echo "#year/day hr:min TZ cpu_1min_avg cpu_5min_avg cpu_15min_avg cpu_hog
hog_cpu% free_mem_mb" >> "$outfile"
while [ 1 -eq 1 ] ; do
unset TIMESTAMP CPU_USAGE CPU_HOG FREE_MEM
TIMESTAMP=`date -u '+%Y/%j %k:%M UTC'`
CPU_USAGE=`uptime | sed -e 's/^.*average://' -e 's/,//g' -e 's/^ //'`
CPU_HOG=`top -b -n 1 | sed -e '1,7d' | head -n 1 | awk '{print $12 " "
$9}'`
FREE_MEM=`free -m | grep 'buffers/cache' | awk '{print $4}'`
sleep 1
echo "$TIMESTAMP $CPU_USAGE $CPU_HOG $FREE_MEM" >> "$outfile"
sleep `expr $interval - 1`
done
(plot)
file=cpu_use.xblade13
cat $file.log | sed -e 's/^#.*//' | cut -f2 -d/ | \
tr ':' ' ' | tr -s ' ' | cut -f1-3,5 -d' ' | awk \
'{ if(/./) {printf("%f %s\n", $1 + $2/24 + $3/(24*60), $4)} else {print}
> $file.prn
( cat << EOF
set terminal svg size 800 480
set output "cpuload.svg"
set grid
set xlabel 'Time (day of year, UTC)'
set ylabel 'CPU load (1 minute average)'
set title 'xblade laods, May 26 2010'
set label "httpd" at 147.332, 6.5
set label "rsync" at 147.278, 3.9
set arrow from 146.8,1 to 148,1 nohead lt -1 lw 0.75
plot "cpu_use.xblade14.prn" title 'xblade14' with lines lt 8, \
"cpu_use.xblade13.prn" title 'xblade13' with lines lt 3
EOF
) | gnuplot
inkscape --file=cpuload.svg --export-png=cpuload.png -b white
regards,
Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/574#comment:3>
OSGeo <http://www.osgeo.org/>
