#580: VM on osgeo4 for GeoNetwork opensource
Reporter: ticheler | Owner: sac@…
Type: task | Status: new
Priority: major | Component: Systems Admin
Keywords: |
The GeoNetwork developers would like to have a new server to host the
GeoNetwork user website and documentation. The server will also be used
for automatic builds and possibly more project specific requirements.
We would like the server to be available as geonetwork.osgeo.org and will
later update our DNS entry for geonetwork-opensource.org to also point to
this server.
Several reasons exist for this request. Among others is the dependency on
the current hardware that has been failing, the need to consolidate the
User website, user and developer documentation and build processes.
Ticket URL: <http://newtrac.osgeo.org/osgeo/ticket/580>
OSGeo <http://www.osgeo.org/>
Keywords: |
Comment(by crschmidt):
The right place to put this is the 'projects' vm, which we are currently
having set up. Will update this ticket when the projects vm is set up.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/580#comment:1>
Priority: major | Milestone:
Component: Systems Admin | Keywords:
Comment(by wildintellect):
Clarification: the website and documentation are welcome on the projects
vm. The automatic builds needs to occur on the buildbots(blades) at
telascience. If you need access to those machines and don't already have
it or aren't sure where to setup your build environment a new ticket would
be good for that component.
That said, the projects vm is under way, we're just working out the
permissions and standard practices to ensure projects don't step on each
other.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/580#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by warmerdam):
* status: new => closed
* resolution: => fixed
Comment:
The ProjectsVM is operating and there are some details available at:
http://wiki.osgeo.org/wiki/ProjectsVM
Please let me or SAC members know if there are specific questions. Please
document services setup on the ProjectsVM with a link off the ProjectsVM
wiki page.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/580#comment:3>
