#621: symbolic link to /usr/local/share/udig/udig-data
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
This was formally available via the users home directory "data" folder;
this no longer is available allowing uDig to fail
http://wiki.osgeo.org/wiki/Live_GIS_Disc_Testing as the quickstart does
not match the dvd contents.
Was a decision made to handle the data directory differently?
Going through the script I find that data ends up in:
- /usr/local/share/udig/
Can the symbolic link be restored or can we put the data in the users home
directory as is done for other sample data?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/621>
OSGeo <http://www.osgeo.org/>
Comment(by jive):
It actually looks like the "data" folder in the users home directory
points to /user/local/share/data?
So I recommend adding a symbolic udig-data to /usr/share/data folder? I
will need some help/review of the install_udig.sh script to make this
happen.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/621#comment:1>
#621: symbolic link data /usr/local/share/udig/udig-data
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by jive):
* status: new => closed
* resolution: => fixed
Comment:
I was not able to sort out a symbolic link; but did change the
install_udig script to unpack a udig_data folder in /usr/local/share/data
/udig-data
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/621#comment:2>
Component: LiveDVD | Resolution: fixed
Keywords: |
Changes (by jive):
* component: Systems Admin => LiveDVD
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/621#comment:3>
Keywords: |
Changes (by hamish):
* cc: live-demo@… (added)
Comment:
please move the ML email addr from the owner field if you take ownership
of a ticket so it doesn't get lost
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/621#comment:4>
