#623: Insufficient Storage
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Now that the webdav folder is back I am catching up on releasing geotools.
[INFO] Error deploying artifact: Failed to transfer file:
http://download.osgeo.org/webdav/geotools/org/geotools/geotools/2.6.5/geotools-2.6.5.pom.
Return code is: 507 Insufficient Storage
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/623>
OSGeo <http://www.osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by warmerdam):
* status: new => closed
* resolution: => fixed
Comment:
Jody,
I have trimmed a few old things from the download tree and freed up a bit
of working room.
SAC,
The following is the disk use. As you can see the big users are the
livedvd and ossim. Note that due to the way we backup and restore stuff
that had been previously deleted from the download server may have been
restored. Cleanup may be in order. We now have about 35GB free.
warmerdam@xblade13:/osgeo/download$ sudo du -s -c -h *
15M benchmarking
1.2G buildkit
2.6G fdo
890M fossgis-de-live-dvd
123M fusion
940M gdal
37M geos
317M geotiff
453M grass
4.0K index.html
5.1M libspatialindex
139M libtiff
16G livedvd
1006M logs
4.9G mapguide
371M mapserver
9.1G osgeo
1.9G osgeo4w
20G ossim
3.7G pgrouting
255M proj
4.0K proj4j
4.0K pub
2.1G qgis
4.0K robots.txt
2.5M shapelib
2.5G webdav
68G total
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/623#comment:1>
Keywords: download |
* keywords: => download
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/623#comment:2>
Comment(by jive):
Thanks *so* much Frank; I have had a release day from hell (actually
managed to check out the wrong tag and go most of the way through before
finding my mistake; and then finally recovered in just in time to run out
of room).
I was pretty sure that geotools would be a massive user of disk space; but
perhaps we just have many many small files.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/623#comment:3>
Type: task | Status: reopened
Changes (by aaime):
* status: closed => reopened
* resolution: fixed =>
Comment:
It seems we're back at the starting point... trying to copy over some
files with "cadaver" (just to make a test) I get "507: Insufficient
storage"...
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/623#comment:4>
Changes (by aaime):
* cc: aaime (added)
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/623#comment:5>
* cc: jef (added)
Comment:
Funky, there is a strange super-sized file in the OSGeo4W tree which I
think was uploaded by Jurgen. I deleted it yesterday but now it has
reappeared.
warmerdam@xblade13:/osgeo/download/osgeo4w/release/qgis/qgis-dev$ ls -l
*1.6.0-
12*
-rwxr-xr-x 1 jef users 35884290048 2010-08-10 01:29 qgis-
dev-1.6.0-12.tar.bz2
I have deleted it again, but perhaps Jurgen can comment on why it is
appearing and ensure it doesn't reappear?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/623#comment:6>
Comment(by jef):
Replying to [comment:6 warmerdam]:
Ouch. It was overwritten with zeros, when it should have been truncated
(yes, {{{dd if=/dev/zero of={}}}} is quite different from {{{dd
if=/dev/null of={}}}}).
The idea was to produce an empty file, before removing it the next day so
that mirror jobs would save space by also truncating their files even if
the don't delete them later. Should work that way now.
But I didn't notice that you removed the file. When I checked everything
looked ok, so I thought it was a some kind of webdav problem.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/623#comment:7>
Changes (by jef):
* status: reopened => closed
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/623#comment:8>
