#643: Frequent transient errors on various trac
Reporter: pcav | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Internal Server Error TracError: AttributeError: 'module' object has no
attribute 'cbook'
and others.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/643>
OSGeo <http://www.osgeo.org/>
Comment(by pcav):
Also, from qgis stats:
File "/usr/lib/python2.5/site-
packages/Trac-0.11.7-py2.5.egg/trac/web/api.py", line 376, in send_error
'text/html')
packages/Trac-0.11.7-py2.5.egg/trac/web/chrome.py", line 733, in
render_template
message = req.session.pop('chrome.%s.%d' % (type_, i))
packages/Trac-0.11.7-py2.5.egg/trac/web/api.py", line 195, in __getattr__
value = self.callbacks[name](self)
packages/Trac-0.11.7-py2.5.egg/trac/web/main.py", line 265, in
_get_session
return Session(self.env, req)
packages/Trac-0.11.7-py2.5.egg/trac/web/session.py", line 162, in __init__
self.get_session(req.authname, authenticated=True)
packages/Trac-0.11.7-py2.5.egg/trac/web/session.py", line 178, in
get_session
super(Session, self).get_session(sid, authenticated)
packages/Trac-0.11.7-py2.5.egg/trac/web/session.py", line 59, in
get_session
(sid, int(authenticated)))
packages/Trac-0.11.7-py2.5.egg/trac/db/util.py", line 64, in execute
return self.cursor.execute(sql_escape_percent(sql), args)
InternalError: current transaction is aborted, commands ignored until end
of transaction block
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/643#comment:1>
Comment(by crschmidt):
pcav: Are these errors reproducible on some given URL? I don't know hwat
you mean by 'qgis stats', but there's probably a fair chance that any
plugins written again 0.10 (old machine) don't work on the newer 0.11.
Same question applies to 'cbook'; I've never seen that error before.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/643#comment:2>
Comment(by pcav):
The cbook error happens often on https://trac.osgeo.org/qgis/ but it is
difficult to reproduce, as it happens only at random intervals.
The plugin error comes from: https://trac.osgeo.org/qgis/ticketstats
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/643#comment:3>
Reporter: pcav | Owner: strk
Type: defect | Status: closed
Component: Trac | Resolution: worksforme
Keywords: |
Changes (by strk):
* owner: sac@… => strk
* component: Systems Admin => Trac
* status: new => closed
* resolution: => worksforme
Comment:
Closing as obsoleted by trac upgrades (and qgis trac isn't in use anymore
either).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/643#comment:4>
