#644: DNS resolution issue with CURL on AdHoc VM
Reporter: dmorissette | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Some DNS resolution issues with programs using the CURL library have been
reported on the AdHoc VM recently: CURL is unable to resolve any hostname.
OTOH, dig on the same hostname does work:
dmorissette@adhoc:/tmp$ curl -v http://www.google.com/
* getaddrinfo(3) failed for www.google.com:80
* Couldn't resolve host 'www.google.com'
* Closing connection #0
curl: (6) Couldn't resolve host 'www.google.com'
dmorissette@adhoc:/tmp$ dig www.google.com
;; ANSWER SECTION:
www.google.com. 604759 IN CNAME www.l.google.com.
www.l.google.com. 259 IN A 74.125.155.106
Based on a quick web search, it seems that this kind of problem is related
to the "hosts" setting in the /etc/nsswitch.conf.
We currently have the following line in /etc/nsswitch.conf:
hosts: files mdns4_minimal [NOTFOUND=return] dns mdns4
... and I verified that if I put "dns" before "mdns4_minimal" then CURL
works fine:
hosts: files dns mdns4_minimal [NOTFOUND=return] mdns4
I would also note that I checked two other VMs (projects and backup) and
none of them has the mdsn4 stuff, only a simple
hosts: files dns
... so it seems that someone intentionally changed this in the AdHoc VM
since it was created.
Unfortunately I don't know enough about the nsswitch.conf and mdns4 to be
sure that the proposed fix above won't have other bad side-effects.
Hopefully whoever added the mdns4 stuff will see this ticket and can
confirm that the change to put "dns" right after "files" would be fine.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/644>
OSGeo <http://www.osgeo.org/>
