#650: Establish osgeo/ossim wiki as ossim.org
Reporter: mlucas17 | Owner: sac@…
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
The OSSIM project would like to establish http://trac.osgeo.org/ossim/ as
www.ossim.org. Need to determine the IP address to point DNS to and make
internal changes so that it responds to the ossim.org domain. Mark Lucas
controls the ossim.org domain (mlucas17) and will make any necessary
external adjustments.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/650>
OSGeo <http://www.osgeo.org/>
Comment(by crschmidt):
SAC,
There are problems with doing this trivially because of the way trac is
set up; it's essentially designed to be used under a subdomain. If you
look at the 'openlayers' file in /etc/apache2/sites-enabled/, I believe it
has some of the setup neccesary, but logging in under that domain never
worked (Which is why OL switched to trac.osgeo.org/openlayers instead.)
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/650#comment:1>
Component: Systems Admin | Resolution:
Keywords: |
Changes (by Mateusz Łoskot):
* cc: Peter Borissow <peter.borissow@…> (removed)
* cc: peter.borissow@…, strk (added)
Comment:
ossim.org has been now redirected to http://trac.osgeo.org/ossim/ for a
while
Sandro, perhaps this can be closed now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/650#comment:2>
Type: enhancement | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
Yup, closing, thanks.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/650#comment:3>
