#653: LDAP set up for both new servers to access?
Reporter: tmitchell | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Quick question.... I'm setting up the test migrated drupal instance (on
.66) and wondering if LDAP should work from there, or if something on the
LDAP side needs to be set up to listen for requests from it.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/653>
OSGeo <http://www.osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by crschmidt):
* status: new => closed
* resolution: => fixed
Comment:
Since you didn't give any other information, I'm going to assume that the
first part of the IP address is "140.211.15"; if so, all IP addresses in
this block are allowed. If we were assigned any other IP addresses outside
that range, please feel free to reopen the ticket, and I will add them to
our allowed IP ranges.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/653#comment:1>
