#659: Updating email address doesn't work
Reporter: christoph | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: email, ldap
Currently, my mail address (christoph at osgeo dot org) is being forwarded
to (christoph dot baudson at wheregroup dot com). I want to forward it to
a new address (christoph at baudson dot de).
Here's what I did
* Visited https://www.osgeo.org/cgi-bin/auth/ldap_edit_user.py
* Updated data. Now, the new address is correctly displayed. So I assume
the LDAP entry has been updated successfully.
* Sent a test mail to christoph at osgeo dot org. Still being forwarded
to the old address. Expected it to be sent to the new address.
Any idea what can be done?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/659>
OSGeo <http://www.osgeo.org/>
Comment(by martin):
The OSGeo mailer refers to a simple aliases text-file for these virtual
addresses. I'll adjust your entry accordingly, please test and close the
ticket upon success.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/659#comment:1>
Comment(by christoph):
Thanks a lot for addressing this ticket!
Unfortunately, another (worse) problem arose: Sending mail to christoph at
osgeo dot org fails altogether. I got this error message from MAILER-
DAEMON
Sender address rejected: Access denied (in reply to RCPT TO command)
Any idea?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/659#comment:2>
Comment(by martin):
Hi, you forgot to include the relevant part of the message:
host baudson.de[IP-address] said: 554 <...sender...>: Sender address
Actually, that's something you'll have to figure on your own EMail relay,
I don't have access to that one ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/659#comment:3>
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
actually there seem to be recurring issues with mail from and to OSGeo,
others have reported similar troubles before (including me). Could it be
that our mail system is not trusted by other services for some reason?
Could we tweak our mail relay to look less fishy?
Please don't answer that the problem is on the recipient's end, I heard
that one before. If there are more recipients with similar problem then
we should look into it from our end.
Best regards,
Arnulf
Comment(by martin):
Sac mailing list
Sac@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/sac
Arnulf Christl
Exploring Space, Time and Mind
http://arnulf.us
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iEYEARECAAYFAk0HO90ACgkQXmFKW+BJ1b2yWgCfXh9O2RrxbDYDKYCHAvuiK5uX
CW4AnRYTod9ncXkydBk/RDGGtzH3NeDD
=pce1
-----END PGP SIGNATURE-----
Type: defect | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: email, ldap |
Changes (by christoph):
* status: new => closed
* resolution: => fixed
Comment:
Thanks Martin for your incredible responsiveness.
I should read and understand the error message before posting it.
It works!
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/659#comment:4>
