#660: GeoNetwork Trac fails
Reporter: ticheler | Owner: sac@…
Type: task | Status: new
Priority: blocker | Milestone:
Component: Systems Admin | Keywords:
I tried to enable the SensitiveTickets plugin on Trac. This caused the
Trac to completely fail now
Sorry about that. It says an upgrade
should be ru:
Trac Error
TracError: The Trac Environment needs to be upgraded.
Run "trac-admin /var/www/trac/geonetwork upgrade"
Hope someone can do this very soon to get the Trac online again. Thanks in
advance!
Jeroen
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/660>
OSGeo <http://www.osgeo.org/>
Comment(by neteler):
I tried to execute this command but it asks me a password which I don't
know:
tracsvn:~# trac-admin /var/www/trac/geonetwork upgrade
Password:
So I leave that to another SAC member.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/660#comment:1>
Comment(by aboudreault):
I disabled the sensitive plugin to get trac working again. I tried to
install the sensitive plugin recently and it was not working very well(The
upgrade did not work). For the moment, let it disabled and I will check
this again in the next few days.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/660#comment:2>
Comment(by ticheler):
Thanks a lot!
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/660#comment:3>
ticheler, could you check if you can the SecureTickets plugin, which is
installed on the system. See
http://wiki.osgeo.org/wiki/Trac_Instances#Secure_Tickets
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/660#comment:4>
sorry, *if you can use*
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/660#comment:5>
Priority: normal | Milestone:
Changes (by wildintellect):
* priority: blocker => normal
Comment:
Is this still an issue?
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/660#comment:6>
Reporter: ticheler | Owner: strk
Type: task | Status: closed
Component: Trac | Resolution: worksforme
Keywords: |
Changes (by strk):
* owner: sac@… => strk
* status: new => closed
* component: Systems Admin => Trac
* resolution: => worksforme
Comment:
Closing as it works for me
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/660#comment:7>
